AC HD 16 DOSER TOUQURE CONVERTER - diesel fuel ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: AC HD 16 DOSER TOUQURE CONVERTER - diesel fuel ?
    Posted: 21 Mar 2011 at 7:26pm
I was just on a Heavy Equipment forum and they were talking of diesel fuel running thru the tourque converter on a HD 16  ? Howd that work ??
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2011 at 8:00pm
I don't know a lot about torque converters but they did use diesel as the fluid in some of the early ones on dozers.Caterpillar had problems with them so they changed to using oil in later ones in Caterpillar D8 any way.
HD6 Merv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6 Merv Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2011 at 12:20am
Allis Chalmers were the first to use a torque converter in a crawler tractor. It was a 3 stage twin disc unit in the HD14C. and used diesel fuel as its drive fluid.
Next came the HD19 and 15 then the 20, and early HD16s and 21s.
Later HD16AC and DC models and HD21A models changed to a single stage oil filled converter.
Merv
doc mopar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote doc mopar Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2012 at 9:34pm
i have hd16 i rebuilt torque convertor in years ago that runs on diesel fuel if anyone tries to rebuild one be very carful taking it apart the inside is made of carbon and will break very easy just wanted to let everyone know hope this helps
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2012 at 10:32am
Operators have told me that as long as the tank was full of fuel to absorb the heat you were OK, With low fuel late in the work day, the torque converter temperature would  rise dramatically.
