AC G block repair |
Post Reply |
Tracy Martin TN
Orange Level Access Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10645 |
Posted: 04 Feb 2012 at 8:52pm |
What is most common method to fix the drawbar mounting holes in engine block? I have a block that holes are cracked thru case. I know there are many been fixed. What is the best way to do it? Tracy Martin
dave63
Orange Level Joined: 01 Feb 2011 Location: Lineboro Md Points: 2382 |
In my eyes the only option would be to have it welded. You would want a welder the realy knows what he is doing.
The universal answer to all questions is yes, how much do you want to spend?
Tracy Martin TN
I thought about making a threaded carbon rod, and screw it into a pre-heated block. Weld it with nickel rod, slow the cooling down, and clean it up when cool. I figured there would be several opinions on the fix, but I guessed wrong.Tracy Martin
Edited by Tracy Martin TN - 05 Feb 2012 at 1:33pm |
jaybmiller
Orange Level Access Joined: 12 Sep 2009 Location: Greensville,Ont Points: 22745 |
If shipping wasn't an issue, buying my block that needs a $40 sleeve installed could have been a viable option......sigh...
dave63
Sounds like you know what you are doing.
norm[ind]
Orange Level Joined: 29 Oct 2010 Location: bourbon,ind Points: 2992 |
welded a nose castring for a DC CASE TRACTOR HIGH CROP WAS STILL ON THE TRACTORwhen sold with no complaints weld lots of cast parts welded a snapping roll on a corn picker one time was still on the picker a year later after many acres had 4 threaded holes in it[ ac left hand point]
Tracy Martin TN
I am interested in a couple of blocks if need nothing but boring cylinders. Sleeving if necessary. Tracy Martin
JoeM(GA)
Orange Level Joined: 12 Sep 2009 Location: Cumming,GA Points: 4677 |
Short of a replacement used block, I think this would be the only way to be able to use the drawbar again |
Allis Express North Georgia
41 WC,48 UC Cane,7-G's, Ford 345C TLB |
Tracy Martin TN
Joe, it was a weak point for sure. Loose bolts are what caused these problems or failure of front attaching pivot. Seems every other one is cracked or repaired. Alot of trouble to fix properly. Tracy Martin
Post Reply | |
