AC Forklift with D15 engine |
jpi72
Joined: 27 Jul 2019 Location: Hudson, Iowa Points: 42 |
Topic: AC Forklift with D15 enginePosted: Yesterday at 2:10pm |
I own what I believe is an AC 610 forklift. It has a D15 series II engine (160 cu. in.) Was engine noted to have head problems? The third cylinder lost the keepers on the exhaust valve. We got the valve reattached and replaced with new keepers. Then to find out the that same cylinder has zero compression. After Christmas we will remove the head. Does anyone have experience with this problem?
Joel
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8723 |
Posted: 11 hours 38 minutes ago at 8:29am |
If you dropped a valve I suspect you have a hole in a piston. How were you able to retrieve valve after loosing keepers?
jpi72
Posted: 9 hours 17 minutes ago at 10:50am |
The valve must have been supported by part of the combustion chamber beside the piston. I am fearful we have piston issues. We will know more when we lift the head.
Joel
Les Kerf
Posted: 9 hours 10 minutes ago at 10:57am |
Probably a hole in the piston or a bent/broken valve, maybe both; either way the head needs to off if you intend to fix it. You could blow air in through the spark plug hole with the piston at TDC (firing position) and listen for where the air leaks out. This really won't prove much other than verifying that you have a problem, which you already know
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42081 |
Posted: 5 hours 15 minutes ago at 2:52pm |
Blowing in air will tell if bad piston if air comes from crankcase breather
If air comes from carb - bent or broken intake valve If air heard in exhaust - bad valve on that port . If more than one - you have a big problem - |
