Ac Forklift help
mikef View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikef Quote  Post ReplyReply Direct Link To This Post Topic: Ac Forklift help
    Posted: 18 Apr 2019 at 8:41pm
Just bought a acp60-2ps forklift gas g230 6cly any specs on hydraulic pump like gpm make model also has a Husco 2 spool valve for up down tilt  Forks go up slow but tilt works better .Put pressure gauge on tilt forks forward psi good 1950/2000 tilt back psi lower 1600/jumps 1850 forks up to top psi 450/500 full throttle on all test thanks
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2019 at 9:34pm
It seems like the pump is ok, perhaps the valve not working right?  I've got a little AC forklift, haven't used it much lately as I have a bigger 521 that does the job better.  Anyway, I lifted something off a truck with the little one the other day and it wouldn't go down.  I hung a 2 bottom plow on it and it still won't go down.  Haven't had time to mess with it.  Good luck on your problem!
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikef Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2019 at 8:09pm
Thanks will look into valve
