Ac Forklift help |
mikef
Topic: Ac Forklift helpPosted: 19 Apr 2019 at 8:09pm |
Thanks will look into valve
JohnCO
Joined: 11 Sep 2009 Location: Niwot Colo Points: 8992 |
Posted: 18 Apr 2019 at 9:34pm |
It seems like the pump is ok, perhaps the valve not working right? I've got a little AC forklift, haven't used it much lately as I have a bigger 521 that does the job better. Anyway, I lifted something off a truck with the little one the other day and it wouldn't go down. I hung a 2 bottom plow on it and it still won't go down. Haven't had time to mess with it. Good luck on your problem!
Allis Express participant |
mikef
Posted: 18 Apr 2019 at 8:41pm |
Just bought a acp60-2ps forklift gas g230 6cly any specs on hydraulic pump like gpm make model also has a Husco 2 spool valve for up down tilt Forks go up slow but tilt works better .Put pressure gauge on tilt forks forward psi good 1950/2000 tilt back psi lower 1600/jumps 1850 forks up to top psi 450/500 full throttle on all test thanks
