AC Farm Wagon ? |
rustyorange45 ![]() Silver Level Access ![]() Joined: 01 Sep 2013 Location: Vernon Co. MO. Points: 392 |
![]() ![]() ![]() ![]() ![]() Posted: 01 Nov 2018 at 8:40pm |
How many models of farm wagons did Allis Chalmers make? I would like to find one with removable sides and a hoist. Are they a common find or few and far between? What price? Thanks, Tim
1953 WD45 WF/Model 90 Loader, Oxnard Rear Blade, 80R Mower, Model 209 Disc, WD Rear Mounted Scoop, Model 184 & 160 Rotary Mowers, 1952 CA NF/L306CA mower, 1953 CA WF/Model 8 Loader.
bauerd44 ![]() Silver Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Wentzville, MO Points: 350 |
![]() Here is one piece of information that I have. Edited by bauerd44 - 01 Nov 2018 at 9:36pm |
Missouri Allis-Chalmers Club
CA Allis, 175 Allis, 185 Allis |
AC7060IL ![]() Orange Level ![]() Joined: 19 Aug 2012 Location: central IL Points: 3317 |
There are also the following models;
605 ~6 1/2 ton, 700 ~ 7 ton (initial 7 ton followed by the later 701 model), 800 ~ 8 ton, (maybe a later 801 with front tierod?) 1001, & 1010 ~ both later 10 ton models after the 1000. 1010 has front tierod ![]() This wagon below is an early AC 1000 model gear @ 10 ton capacity with 8 bolt wheel pattern. ![]() ![]() This is a J&M gravity box on a later AC 1010 model gear with front tierod design & 8 bolt wheel pattern. ![]() Edited by AC7060IL - 01 Nov 2018 at 10:57pm |
Matt MN ![]() Orange Level ![]() ![]() Joined: 14 Sep 2009 Location: Silver lake MN Points: 1491 |
I would like to find one of the smaller 300 or 305 wagons to add to my collection, does any body have a picture of one?
![]() This is a copy of the AC running gears sales brochure’s front cover printed June 1968. Lower row, from left to right: 505, 405, 300. Upper row, from left to right: 500, 1000, 701. All of these models, except for 500, have their tie-rod assemblies positioned behind the front axle beam. Later 810? & 1010 models had their tie-rod assemblies positioned ahead of the front axle beam. Heres a photo of an AC 1010 model's front tie-rod. ![]() Edited by AC7060IL - 04 Jul 2019 at 5:45pm |
![]() This is page 2 of that same AC running gear sales brochure. It showing a picture of the AC 300 model. Edited by AC7060IL - 04 Jul 2019 at 5:47pm |
