AC D-19 turbo diesel versus JD 4010 diesel
 Post Reply Post Reply Page  <123>
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2017 at 5:36am
I liked my D19 gas. It was the first tractor I bought myself. Bought from a CaseIH dealer in 1987 on Case Credit. It was smooth power and for me it pulled fine and easily out pulled Dad's D17 but we had a pull-type plow. The hydraulics on them leave more than a little to be desired though. The hydraulics never worked right and forget mounted euipment if you needed traction booster. It worked good with a rear mounted 4 row cultivator though and it was our go to tractor for that task. Also did a lot of haying with it. But clearly a 4010 out classes it in most respects although the AC dealership I worked at, the older mechanics told me a D19 gas or diesel would consistently out plow a 4010 in the field demos the dealers used to have back then. I guess a new D19 with knowledgeable operators, like they were, could make em go.
Wink
I am a Russian Bot
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2017 at 7:38am
Wow.  I must be low on coffee....I can't believe some of the things I'm reading!!! Hahaha
JD shift pattern:  My brother in law grew up on IH's.  We had some old JD's , and he helped us in the hay and building fence one summer.  So we had some typical banter, and then one day he said, "I just never figured out how to shift, 1st gear here, and 2nd way over there and so on."  AHA!  I said....They have them numbered by speed, but grouped by range, it was never intended to count up in perfect sequence, so the right hand side had 3, 5, and 6, the left hand had 1,2,4, and R.  Just stay over to the left in the field, and when you're going to pull out on the road, 3 if you're loaded, 5 if you're empty, then 6.
Synchro range is like that, synchronized within a small group of gears, then no synchronized for changing the actual range.  Then a quad shift is just a synchro range with a hi lo splitter in conjunction.
For me, the Allis 7045 is my first Allis.  Having to be at a dead stop to change gears was a huge adjustment for me, then if you're pulling something, like chopping corn and have a full wagon to unhook, you're on a slight incline and rolling a bit and if you don't get it out of gear before the trans break kicks in, everything is all bound up.  This isn't a complaint, it's got it's benefits, and it all takes time to get used to depending on where you began.
Edited by Tbone95 - 11 Dec 2017 at 7:39am
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2017 at 12:52pm
My '68 gas SR 4020 and my '68 MF-135 both have differential lock. Most useful when disking plowed ground and can be used plowing too. The 4020 differential lock (hydraulically actuated) unhitches when a brake is touched, the 135 takes manual disengagement for turning.
Gerald J.
45 turboa- View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 45 turboa- Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2017 at 4:21pm
IF YOU GET THOSE J-Ds ON AN INCLINE IN PARK HAVE FUN TRYING TO PULL IT OUT. IF YOU FINAGILE ENOUGH AND GET IT IN REVERSE IT UNLOCKS. I ALWAYS CALLED THAT SYSTEM WONDER SHIFT !
turbocharged
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 11 Dec 2017 at 7:43pm
I have to say our D19 turbo was the worst AC we ever had-- low torque,lots of down time, hard starting, poor hydraulics, and clumsy for a 65hp tractor. I would compare to the 3010 and still give the thumbs up to the JD. I always enjoyed the sound of the D19 once it was warmed up though and was easy on fuel in my mind.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2017 at 8:18am
Which JD's?  Have a 2640 that's spring loaded to go into park, if on an incline, and doesn't go in right away, let it roll and it slips right in.  No issue whatsoever getting it out.  That one is actually the best park system I've ever operated.  Had a 1520.  That was pretty stiff in park, but if you pulled it out of first first, it wasn't that bad.  No worse than the Allis binding up on an incline, just little different problem, little different way to deal with it.  Those were both TSS transmissions.  Maybe the synchro range was worse.  Never owned one of those, but have operated one.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2017 at 9:00am
Did you pay attention to which tractors were being talked about? I never saw 2640 in the title post. BTW a 2640 has a host of other problems that put that series of tractors in the category of worst owned among Deere owners.
Wink
I am a Russian Bot
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2017 at 9:37am
i have never been on a d19 but i think it could only be compared to a4010 or a early 4020,   because the late 4020 is a very differant tractor the late one is 10x the tractor  this post caught my eye because i just stareted on an inframe on a late 4020 this guy has an eary one also
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2017 at 9:53am
Wow, take it easyBig smile.  Yes, I paid attention, just sort of asking for clarification.  A lot has been talked about since the title post.  Was a 190 XT in the title post?  How about a MF 135?  Did you jump on that guy?
BTW, we have owned and used hard our 2640 for over 30 years, and it's really never given us any trouble.  There's wear and tear and we do our maintenance.  I guess I'm "lucky".
Edited by Tbone95 - 12 Dec 2017 at 9:54am
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2017 at 11:05am
I'm just imagining Dr. Allis sitting back and laughing at all of you after reading the mess he started! LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2017 at 11:53am
The 2-cylinder tractor was obsolete. It took from 1953 to 1960 for John Deere to develop the New Generation 3010/4010 tractors. Where was the rest of the tractor builders during this time??  Here's what should have happened. A-C should have released the D-19 in 1958 and the diesel engine should have been a bored block at 290 cubes. The hydraulics should have been "live".  The mighty One-Ninety should have been released in 1961 with a truly independent PTO. The "XT" should have been thoroughly tested before it was sold to the HP hungry Customers in 1963, instead of 1965.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2017 at 11:55am
4010/4020 didn't have any "park" issues. That was quad-range 4430's and the like. History is pretty clear sometimes. Deere replaced the long obsolete two-banger series with a 7 year adventure of developing the 3010/4010 tractors. These new tractors forced everyone else to scramble and come up with something new too. Look at the MF 1100 tractor: closed center hydraulic pump driven off of the crankshaft, hydrostatic power steering, planetary final drives and wet brakes, etc, etc. The MF1100 was clearly a 4010/20 wannabe. IH had to release the 706/806 in 1963.  A-C finally came with the mighty One-Ninety in mid/late 1964 just AFTER Deere released the 4020 !! The One-Ninety set some new highs in the operator comfort zone that took Deere another decade to match. Large, flat, high deck platform. Suspended clutch and brake pedals. Console control !! (which soon became an industry standard for others). Tilt steering wheel. sloping tapered hood design. 48 gallon rear mount fuel tank. To this day, operating a 190/200 tractor is still about as good as it gets for the operator. BUT, the lack of a real independent PTO haunted this tractor when trying to convert a brand X customer over to A-C. Also, the fact that 77 HP never matched a 4010's 84 HP and now the 4020's 94 HP didn't help either. So, some genius engineer (or salesman) decided to install a turbo-charger on the One-Ninety XT to compete with the 4020, which it did, until the transmission or ring and pinion ate their pigs. I started this post earlier this morning, so it is a little out of synch........
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2017 at 11:57am
Dave, I'm actually surprised everyone is kinda voicing in favor of the Deere 4010/20. I love a good late model 4020, but I'm surprised....it seems a lot of other guys do, too.
As far as the 2640...my late grandpa had one, and it was a nice tractor. I always thought the 2010 was the worst Deere ever made (almost bought one once), but maybe we shouldn't elaborate on that. Big smile
That said....maybe I like the 4020 because I've never ran a One-Ninety? That's on my bucket list of things to do someday...
Edited by CrestonM - 12 Dec 2017 at 12:00pm
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2017 at 12:10pm
I didn't read them all but for some reason I'm drawn to you. Wink BTW I think you took my tone a lot harsher than I figured. Almost every model tractor built by anyone gets a bad review from somebody but if you search a "2640 worst tractor" there will be more hits on that model than usual. Don't ask me what the problems are, I don't remember all what I read. A friend of mine had a 26 or 2840 and he did have a lot of nickel and dime issues. Now he has a New Holland.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2017 at 1:00pm
Drawn to me?  Naw!  Say it ain't so!  LOL
And imagine that, the park issue didn't apply to the tractors from the title of the post!  hahahaha
Only "issue" with my 2640 I'd say is cooling capacity, you have to watch it when using it hard.  But it truly has been a phenomenal tractor for reliability.  It was actually pretty funny, 4 years ago in crop season, I had 2 other tractors down including my Allis, and another too small to be much help.  The 2640 literally did every task that spring, including pulling my field cultivator.......wings up though!WinkLOL
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2017 at 1:54pm
Every brand of tractor has their hero’s and zeros. I think we are comparing one of each. What always strikes me as funny is that you never hear a bad thing about a D17 but just turn the corner and you find someone who doesn’t like a D19.   And they’re not that different. The other thing I find funny as that the duds are now the most collectible. D19 turbo diesel, WD45 Diesel. Both have a reputation of having engine problems. Just thinking out loud.
SteveMaskey(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveMaskey(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2017 at 3:30pm
Dad bought a D17 when I was in high school. I am now 65 and the D17 is still used every day feeding. It went through 3 teenagers and It is wore out from one end to the other but still going. We pulled 4 14” plow with it back in the day when we moldboard plowed everything. There are 3 D19’s out there plus others but in my experience the D17 is about as bullet proof as it gets
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2017 at 3:47pm
I always said a series 4 D-17 gas was my "4020".  Every part of the tractor was built just rugged enough to last a long time without any problems. Every S4 gas I ever overhauled (and there were many) never needed the crankshaft reground. That was a far cry from the first D-17's that had some crank/oil pressure issues. My Dad's S4 to this day has never had anything done to the transmission, differential or anything in the torque housing except hand clutch ramps and rollers one time. Tractor has 10,000+ hrs on it and the diamonds on the clutch and brake pedals are pretty much smooooth.....
JayIN View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2017 at 3:50pm
When I farmed 80-96 I had a 3020gas 4020D a 190XT III a D15II 2 WD and 1 WD45 and a 880 Oliver. When I was on the platform of that 190XTD I felt like I was the King of The World. It is a FEELING. We all have these feelings.Like Ford-Chev-CPD. Something sucked about each one of them.Only one remains today-WD45.Dad bought it in 1968. Long live ALLIS CHALMERS!
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2017 at 4:06pm
Pre 1964 there were several tractors ahead of AC. Basically any tractor with a GOOD diesel engine,Good LIVE hydraulics and a 3 Pt. Hitch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2017 at 5:51pm
RE the jd "new generation" tractors, jd wouldn't have them, if they didn't have cat design them, in exchange for that, jd was supposed to stay out of the construction/industrial market...  We all know how that turned out...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2017 at 5:57pm
Dang was that the. Cat JD relationship? Always heard of something,
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2017 at 5:57pm
Wow, Dave! Is that really how it worked? Sounds like a great piece of information to know..
Talking about Cat designing the New Generations to keep Deere out of the industrial sector... I've heard that Steiger built a prototype 2wd tractor (the Jaguar) and planted it on a farm in the Moline, Ill area as a warning to Deere to stay out of the 4wd market, or Steiger would invade the 2wd market. We see how that worked, as well.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2017 at 6:25pm
Thanks DrAllis for sharing that era's highlights. I was a kid during the late 1960s & remember seeing all those models in our farm community. I never ran a MF1100, but put some hours on IH 706 & 806s, AC 190xt diesel, & JD4020 diesels. One farm had the bigger Ford 7000,9000- can't remember which?? Mostly though, the local elevator wagon lines during harvest were outnumbered with many older AC WDs & WD45s pulling loaded flare box wagons (with feed sacks covering inside of tailgates) on David Bradley gears. Great memories!
Post Options Post Options   Thanks (1) Thanks(1)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2017 at 6:34pm
When Deere finally went 6 cyl in 1960, Oliver had an ad that was "6 for a quarter" meaning they had been building 6 cyl engines for 25 years.
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2017 at 7:11pm
wekracer,you stated that a D-17/D-19 were "NOT THAT DIFFERENT". We ran a series II D 17 for years and Dad (he admits it) FOOLISHLY traded it on a D-19. IMO, the Only thing "not that different" Was the PERSIAN #2 paint. Perhaps the series III '17 was a closer match??
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomstractorsandtoys Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2017 at 7:27pm
  If that would have happened there would be alot more orange tractors. I like the 190 but we use our pto on to many jobs for me to want to go to that as compared to my 4020's. Pre 1960 I would have been all orange or maybe an Oliver. Tom
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2017 at 7:41pm
i totaly agree with Dr. Allis ,   what should have happened
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2017 at 7:49pm
Out there somewhere is an Allis Chalmers ad for the 7000 series when it came out. It emphasizes everything that it had that Deere and the other brands didn't. I Think that nobody had anything on Allis then. And I certainly don't understand all of the D19 bashing. I love mine. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Dec 2017 at 7:52pm
To be honest I don’t think I have ever run a D19. We have 3 series 4 D17s and I must agree with doc regarding their ruggedness. I’ve really not had much experience with pre s4 17s either. We did have a D15 II so I’m familiar with the hydraulic drawbacks. But from what I’ve seen a 19 is just a pre series 4 D17 with six cylinder engine and maybe different final drives. The hydraulics were a big drawback which is why dad said he never wanted one.   Heck. The only difference between a 180 and s4 17 is the 301, power director and sheet metal. From what I’ve heard all the D series gas tractors were reliable. All the diesels has bad reputations. But I admit I don’t have much experience with some of them. Correct me if I’m wrong.
Edited by wekracer - 12 Dec 2017 at 7:54pm
