AC D10 III, D12 III
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Topic: AC D10 III, D12 III
    Posted: 13 Feb 2012 at 11:29am
I am getting a D12 III together and have a complete power steering from an I-40 to put on in place of the standard armstrong steering.
Question is where can I get new hydraulic lines made for the pressure lines and also the cylinder lines for the ram, these are part steel and part hose?
Next question is would a custom cylinder mount be objectional should someone want to restore this tractor in the future?
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 9:11pm
Joe, are you going to have full hydrastatic power steering? I've found a parts D-10 with power steering and plan to install the power steering on my D-12 III. I have seen it done. You can do what you want, its your tractor. It would be wise not to modify anything to the extent that it couldn't be put back to originial by the next owner.
Allen Dilg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allen Dilg Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 9:27pm
  Hello Joe   I have an I-40 that leaked bad around the valve area, bought new lines and fittings bent and formed to fit.  Try a hyd shop.  Good luck
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 10:28pm
Joe I'd like to do the same to my D12, but it is hard to take that first step.  No power steering  sucks on these tractors when you put a loader on them. Doesn't help when they have a crappy steering box to begin with!
ALLIS EXPRESS!
This year:
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2012 at 10:30pm
Joe try asdales hyd. in mexico mo.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 5:16am
With Hydrostatic steering what happens if you are going down the road and a hydraulic hose breaks ?
Hang on !!
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 6:24am
Hang on !!
Gary
Apply brakes as needed!
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 9:20am
Hi Joe
The point I was hinting at is - to my understanding - SOME  Hydrostatic steering does not have a direct link betwwen the steering box and the front wheels.
SOOOOO  if a hydraulic line breaks the wheels immediately turn hard left or hard right to the end of  maximum travel.
Not sure if this would be the case with a D-10 with "Factory"  PS.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 9:34am
Power steering on the D-10/12's is actually a power assist to the mechanicial steering.
I-40/400 has full hydrastatic steering with no mechanicial connection to the steering wheel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Feb 2012 at 10:03am
Hi Joe
Gary
Many AC models have hydrostatic steering and I have never heard of an accident because of it...I did have a 170 once that I had to keep turning the steering wheel in order to go straight on a sidehill, otherwise all the models I have had have worked well and have "fingertip" steering.
ALLIS EXPRESS!
This year:
This page was generated in 0.071 seconds.
