AC D grader, Gas to Diesel |
Cooper ![]() Bronze Level ![]() Joined: 03 Oct 2010 Location: Charlotte Points: 2 |
![]() ![]() ![]() ![]() ![]() Posted: 05 Oct 2010 at 1:08pm |
I just found out you can't use a IPad to log in. Sorry
I have a 1960's D motor grader. We think it has about a 65 HP gas engine, 4 cyl.
The timing gear went out and they want almost $900 for the two gears.
I would like to put a diesel in it. What kind of diesel can I buy that would fit.
Also where do you find one.
Thanks
Wayne Cooper
Charles Craig ![]() Bronze Level ![]() Joined: 12 Sep 2009 Location: Oro Grande CA Points: 48 |
When my "D" grader arrived with the oil and coolant too friendly, Iput a wd45 used engine in it. has enough power to spin the tires and wasnt too difficult by my self. CC
AC BD3 roadgrader "D" road grader SIX "old" cars Farmall 300
DonBC ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Courtenay, BC, Points: 946 |
The D grader uses the 226 gas engine common to the popular D17 and 175 farm tractors. There should be used parts and even used engines available for less trouble and cost than trying to switch to a diesel engine. The diesel engine used for these same farm tractors was used in the DD graders but the engine is slightly longer so some modifications are still required. Try posting on the farm equipment section for your timing gears. Did the timing gears break because of a governor weight failure?
Calvin Schmidt ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Ontario Can. Points: 4547 |
Lots of good 226 engines available out of Gleaner E combines.
cocochen ![]() Bronze Level ![]() ![]() Joined: 15 Apr 2011 Location: ? Points: 1 |
Edited by CTuckerNWIL - 11 May 2011 at 12:17pm |
