A-C Bal Pak bearings |
Post Reply |
AllisFreak MN
Orange Level Access Joined: 07 Dec 2009 Location: Minnesota Points: 1553 |
Posted: 29 Aug 2010 at 8:22am |
I found some used bal pak bearings for my old disk and was wondering if it would be wise to attempt injecting some grease into them? I have a grease needle that could possibly be worked thru the seal. Has anyone ever found a cheaper replacement for these oddball bearings?
Thanks in advance. |
Chris/CT
Orange Level Joined: 11 Sep 2009 Location: Niantic, Ct Points: 1939 |
I do not see anyway of injecting grease into the ball bearing portion of the Bal-Pak. You could add to the grease cavity's on either side of the ball bearing. If you do try drill into center section thyen inject your grease, close-up hole with whatever you choose. I was unable to find any bearing that matches the Bal-pak dimensions.
Post Reply | |
