AC B1 Tractor |
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3985 |
Topic: AC B1 TractorPosted: 19 Jul 2012 at 11:33pm |
I went to look at a collection of AC stuff that a local guy had for sale. He had a lot of AC machinery like rotobalers, rakes, cultivators and mowers also but he wants to sell it all as a lot. Also has a lot of manuals and misc. parts, again, only will sell as a package.
I managed to pry this loose from him. It seems in decent shape even though it hasn't been run for a while. Came with mower deck, sickle mower, rototiller, snow blower and blade. |
D-allis Iowa
Joined: 05 Oct 2009 Location: Akron, Iowa Points: 494 |
Posted: 20 Jul 2012 at 6:58am |
very nice.
Reindeer
Joined: 14 Sep 2009 Location: Calgary, AB Points: 655 |
Posted: 20 Jul 2012 at 10:06am |
Hi Phil I saw that on Kijiji, looked interesting. Would have had to build on my shed to get the wife to agree, so glad it went to you. Enjoy.
Edited by Reindeer - 20 Jul 2012 at 10:06am |
bigcountry48
Posted: 20 Jul 2012 at 10:33am |
Some guys get all the luck, great find!
1950 B, 1952 pulling wd, and 1954 wd45
Alberta Phil
Posted: 20 Jul 2012 at 11:13am |
I'm not used to working on an Allis this small. I will have to get a manual before I go too far. The electric start system using the generator as a starter is a neat feature. I'm going to change the oil, check out the fuel system and ignition, put in a new battery and see how she goes. The owner said he last used it about 10 years ago. It has been stored in a barn with all it's equipment including the tire chains.
It's a very well built tractor and looks like it was made to last forever compared to most lawn and garden tractors of today. |
bigcountry48
Posted: 20 Jul 2012 at 1:12pm |
If you go to GTtalk, and go to the section marked manuals, they have a manual for it you can down load for free. Also you can test to see if your generator charges by touching a 12 volt light to the far left pole on the voltage regulator( looking at it with the poles facing you). I love the little allises, they are some of my favorites, and I'm dying for a B1. Lastly on YouTube contact zippovarga for extra info, he really knows his stuff on allises and simplicity. Hope this helps!
Alberta Phil
Posted: 20 Jul 2012 at 2:49pm |
Thanks, I'll check that one out. I logged on to SimpletrACtors.com this morning and got some leads there.
Chalmersbob
Joined: 11 Sep 2009 Location: Pennsylvania Points: 2122 |
Posted: 20 Jul 2012 at 9:40pm |
The B-1 is a great little lawn tractor. I just got one the hadn't run for years and sat outside for a while. It sure does a good mowing job for 7 HP. I keep the blades up as far as I can and mow mostly weeds around the fields. I threw a rod in my Simplicity 7114, so the B-1 is doing the work that the CA can't get. Bob
Alberta Phil
Posted: 24 Jul 2012 at 4:00pm |
I got the little B-1 going today. Changed oil, added gas, cleaned points and away she went.
I fixed up a few other minor items and replaced the mower belt and mowed until our daily rainstorm started . It's a great little unit and the 7 1/2 horses must be a lot bigger ones than the 11 ponies powering the JD 111 that I was using, because it'll cut faster and cleaner than the ol' JD. I'm likin' this little unit a lot!!
LionelinKY
Joined: 12 Sep 2009 Location: Radcliff,KY Points: 699 |
Posted: 24 Jul 2012 at 5:45pm |
Dad has a B1 and a B110. Both are VERY gutsy units which mow extremely well. I have a AC608LTD which mows circles both speed and finish wise around my JD210.
CTuckerNWIL
Posted: 24 Jul 2012 at 6:49pm |
Looks like a great set-up. Everything you need to take care of the yard and garden.
Those starter generators caused a lot of problems back in the day. It seems a lot of guys didn't realize the starter part would work even if the generator wasn't polarized. You could start it up with a new generator in it and run for a while before the smoke got out and the battery was near dead, then you needed a new unit. Edited by CTuckerNWIL - 24 Jul 2012 at 6:51pm |
Alberta Phil
Posted: 24 Jul 2012 at 8:46pm |
Couple of pics taken today between rainstorms. Didn't get much mowing done because of all the rain. We've had about 8 inches in the last week and a half!!
SteveM C/IL
Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8981 |
Posted: 24 Jul 2012 at 11:36pm |
I've got a 23D 9hp in mine.Well,actually it's a 9hp block but after a couple bore jobs and 2 broken rods(9hp rods suck) it's now std 10hp piston with 10hp rod and crank and ball brg on flywheel side.
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 25 Jul 2012 at 7:07am |
Hey Phil!
You did great wit' dat! Yer' gonna love playin' wit' the little Allis'. When I restored my 716H a few years ago, I had a ball doing it. Parts weren't that heavy to pick up either like the big Tractors. LOL! As a matter of fact, I can even get up on them pretty easy compared to my large Tractors. But then again, most of my pals here will agree wit' dat'....
Alberta Phil
Posted: 25 Jul 2012 at 10:12am |
I'll have to get a pic of the little guy next to his "great uncle"; a 20-35 'E'!!
Dave Richards (WV)
Joined: 14 Sep 2009 Location: Fairmont, WV Points: 881 |
Posted: 25 Jul 2012 at 10:25am |
Phil, go to one of your discount stores and buy a pair of magnifying glasses. It will look like a B or CA while you work on it. LoL Dave.
