Ac b1 rear end problem
chuck (WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck (WI) Quote  Post ReplyReply Direct Link To This Post Topic: Ac b1 rear end problem
    Posted: 02 Apr 2017 at 11:39pm
Was out with my son on the b1 today and let out brake/clutch pedal went a foot and stopped, looked it over no strange noises drive belt good the shaft with the (not shur what its called) round housing with gears in it,on right side if looking at from the rear turns but axle does not, is there a gear inside on the shaft that has a keyway or a pin trough it that could of sheered off.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Apr 2017 at 10:25pm
That's the differential there is a sun gear and I think it was 4 planet gears in there. The sun gear is keyed to a shaft that runs all the way to the wheel on the other side. The two bolts goin in at an angle press against a nylon bushing that provides limited slip action. The planet gears run on very small pins. It's not very complicated once you take it apart it's pretty easy to figgurout what's wrong. The ones I've had apart the shaft that runs to the other wheel the key way the sun gear sits on has been very trashed. The collar on the outside end keeps the inner axle from sliding out. Once you pull that the differential it's self is keyed to the outer axle.and it slides off. You can lock the diff by turning one ov the planet gears upside down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chuck (WI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2017 at 12:01am
Thanks for the info dave,haven't looked at it yet, going to tie into er this weekend.
