AC B WHAT IS IT WORTH? |
jeff j ![]() Bronze Level ![]() Joined: 02 Dec 2010 Points: 5 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Dec 2010 at 5:24pm |
NEW TO COLLECTING AC. SHEET METAL IS GOOD MISSING BELT PULLY MOTOR STUCK REST SEEMS TO BE THERE HAS BEEN STORED INSIDE THANKS FOR ANY HELP
bikley ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Maryland Points: 5406 |
I would go no more than400
split51 ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Guthrie, OK Points: 713 |
Is it anything special like a low serial number, on steel, arched adjustable front axle,
etc? Edited by split51 - 02 Dec 2010 at 5:34pm |
1929 20-35 sn17662
B1 w/snow blade B10 w/sickle mower B110 w/mower deck B110 w/tiller B112 w/grader blade B210 w/plo |
IT'S NOT ON STEEL DON'T KNOW SER. NUMBER YET THANKS
Blake_AllisMan ![]() Silver Level ![]() Joined: 25 Oct 2010 Location: Plainfield,IA Points: 413 |
I would say about 400 as well
1941 C
1952 IB 1947 C 1955 WD45 SFW 1956 WD45 Diesel 1977 5020 4WD Serial Number 1 |
GBACBFan ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Green Bay WI Points: 2662 |
If you could post a pic or two folks here could give you a lot better idea.
are genuine." - Mark Twain |
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24644 |
Always offer a bit more than current scrap value(so you're not insulting the seller) but remember a nonrunning tractor is very hard to put a price on. A stuck motor could cost $$$$ and you don't know about the clutch,tranny,rearend,etc.Pictures can be priceless ! These guys KNOW their tractors, and you may have a 'diamond in the rough'!!
THANKS EVERYBODY WILL TRY TO GET PICS AND SER# THIS WEEKEND
BennyLumpkin ![]() Orange Level ![]() ![]() Joined: 22 Mar 2010 Location: Centre Hall, PA Points: 2657 |
would be worth much more if its and IB
Central PA Allis Express
1934 WC254 1945 WF 1945 WC135755 1951 WD68085 1953 WD45-150217 1957 WD45D-230744D B110 |
ok tractor # b110772 no pics yet thanks for any help
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 11992 |
Sounds like that would be around a 1950. Could be Battery Ignition....
Steve@B&B |
morton(pa) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Lancaster, PA Points: 1234 |
1950, Electric start, most likely has hydraulics. No more then 400. Where are you located? Please do not use all caps and turn your caps lock off. Thanks.
B26240 ![]() Orange Level ![]() Joined: 21 Nov 2009 Location: mn Points: 3865 |
S/N is found on top of the transmiyion right by the shift lever, also what are the tires like? rubber is expensive.
RUBBER IS GOOD. SHEET METAL SRAIGHT. IS ELECTRIC START. LOCATION WINCHESTER VA. MAN IS ASKING $1200. THOUGHT IT WAS A GOOD DEAL BUT I THINK I'LL PASS. THANKS FOR ALL YOUR HELP
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 87561 |
I have paid $6-800 for running tractors. B is not worth $1200. not running
