AC B WHAT IS IT WORTH? |
jeff j
Topic: AC B WHAT IS IT WORTH?Posted: 02 Dec 2010 at 5:24pm |
NEW TO COLLECTING AC. SHEET METAL IS GOOD MISSING BELT PULLY MOTOR STUCK REST SEEMS TO BE THERE HAS BEEN STORED INSIDE THANKS FOR ANY HELP
bikley
Joined: 12 Sep 2009 Location: Maryland Points: 5406 |
Posted: 02 Dec 2010 at 5:27pm |
I would go no more than400
split51
Joined: 13 Sep 2009 Location: Guthrie, OK Points: 713 |
Posted: 02 Dec 2010 at 5:31pm |
Is it anything special like a low serial number, on steel, arched adjustable front axle,
etc? Edited by split51 - 02 Dec 2010 at 5:34pm |
1929 20-35 sn17662
B1 w/snow blade B10 w/sickle mower B110 w/mower deck B110 w/tiller B112 w/grader blade B210 w/plo |
jeff j
Posted: 02 Dec 2010 at 5:34pm |
IT'S NOT ON STEEL DON'T KNOW SER. NUMBER YET THANKS
Blake_AllisMan
Joined: 25 Oct 2010 Location: Plainfield,IA Points: 413 |
Posted: 03 Dec 2010 at 4:24pm |
I would say about 400 as well
1941 C
1952 IB 1947 C 1955 WD45 SFW 1956 WD45 Diesel 1977 5020 4WD Serial Number 1 |
GBACBFan
Joined: 11 Sep 2009 Location: Green Bay WI Points: 2662 |
Posted: 03 Dec 2010 at 4:26pm |
If you could post a pic or two folks here could give you a lot better idea.
are genuine." - Mark Twain |
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24901 |
Posted: 03 Dec 2010 at 4:37pm |
Always offer a bit more than current scrap value(so you're not insulting the seller) but remember a nonrunning tractor is very hard to put a price on. A stuck motor could cost $$$$ and you don't know about the clutch,tranny,rearend,etc.Pictures can be priceless ! These guys KNOW their tractors, and you may have a 'diamond in the rough'!!
jeff j
Posted: 03 Dec 2010 at 5:04pm |
THANKS EVERYBODY WILL TRY TO GET PICS AND SER# THIS WEEKEND
BennyLumpkin
Joined: 22 Mar 2010 Location: Centre Hall, PA Points: 2657 |
Posted: 03 Dec 2010 at 5:05pm |
would be worth much more if its and IB
Central PA Allis Express
1934 WC254 1945 WF 1945 WC135755 1951 WD68085 1953 WD45-150217 1957 WD45D-230744D B110 |
jeff j
Posted: 06 Dec 2010 at 11:52am |
ok tractor # b110772 no pics yet thanks for any help
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12045 |
Posted: 06 Dec 2010 at 3:37pm |
Sounds like that would be around a 1950. Could be Battery Ignition....
Steve@B&B |
morton(pa)
Joined: 11 Sep 2009 Location: Lancaster, PA Points: 1234 |
Posted: 06 Dec 2010 at 3:47pm |
1950, Electric start, most likely has hydraulics. No more then 400. Where are you located? Please do not use all caps and turn your caps lock off. Thanks.
B26240
Posted: 06 Dec 2010 at 3:51pm |
S/N is found on top of the transmiyion right by the shift lever, also what are the tires like? rubber is expensive.
jeff j
Posted: 06 Dec 2010 at 7:19pm |
RUBBER IS GOOD. SHEET METAL SRAIGHT. IS ELECTRIC START. LOCATION WINCHESTER VA. MAN IS ASKING $1200. THOUGHT IT WAS A GOOD DEAL BUT I THINK I'LL PASS. THANKS FOR ALL YOUR HELP
Joined: 11 Sep 2009 Location: illinois Points: 89317 |
Posted: 06 Dec 2010 at 7:31pm |
I have paid $6-800 for running tractors. B is not worth $1200. not running
