AC B value |
JVON ![]() Bronze Level ![]() ![]() Joined: 04 Dec 2016 Location: Macomb, Il Points: 43 |
![]() ![]() ![]() ![]() ![]() Posted: 18 Jul 2017 at 7:58pm |
I know the subject is pretty broad. What would a cash price be for an AC B I am looking at? I know it is a hand crank and looked reasonably decent from the picture. Currently unsure of the serial number and year. Also it is not running at this time. Just trying to get a baseline idea for price. Currently they are asking $500. I'm pretty sure I could get a better look at it this weekend. I don't really know much more than that. Or even what to look for. Working on my D17 might have spurred the bug to grow the pumpkin patch!
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88315 |
If it don't run, its worth about half that much.......... Check tire condition, look at motor oil, pull the fill plug on the transmission and see whats inside..... check radiator fluid.
I had about $200 in my head as a decent price. Just wanted to make sure I wasn't too far off base. I'll see what it looks like first. From the one picture I saw of it, it looked pretty straight and original. Just not running.
Check if it has been setting inside. see if the motor will bar over ( turn)... If its not locked up, that will help get it started..... gas and spark.
corbinstein ![]() Orange Level ![]() Joined: 31 Jul 2014 Location: Oklahoma Points: 796 |
not running doesn't mean that it's not capable. if it's not stuck, it's worth about $300 to 400 if the tin is straight and the rear tires aren't shot. Is it sitting outside or under a shed? If under a shed it might be better.
jaybmiller ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24738 |
also.. check if mag or dist ignition..
a new (rebuilt) mag will probably cost MORE than teh complete tractor !! jay |
From the one picture I have seen of it, it is in a shed, an open shed, but a shed none the less. I was told if was fixed up several years ago, but like everything else, that all depends on the persons definition of fixed up. I'll see about taking a better look in person Saturday.
Dan Hauter ![]() Orange Level ![]() ![]() Joined: 06 Feb 2011 Location: Carlinville, IL Points: 1258 |
$500. isn't out of the ball park IF the engine isn't locked up, the tires are decent, the sheet metal is all there & straight, & there are no cracks or welds. Check where the tube connects to the engine & look for breaks. Some of these little tractors were used on implements too large & it tore up the frame. That said, a "B" is a fun little tractor to play with. A friend of mine bought a non-running Massey 44 diesel at a farm auction. Went too cheap to pass up. He had 1 of his daughters with him, went to town & bought a battery & some diesel fuel. Had his daughter pull him with the pickup & the tractor started up! Still needed work but ended up being a heck of a bargain.
