AC B Lights |
Ted in NE-OH
Joined: 12 Nov 2009 Location: Austinburg OH Points: 1703 |
Topic: AC B LightsPosted: 12 Jan 2017 at 3:51pm |
I have a B converted to 12V with standard B headlights can I convert the lights to LED. If so what do I buy. Can that be done to a 6 volt light on a B
Hubert (Ga)engine7
Joined: 12 Sep 2009 Location: Jackson Cnty,GA Points: 6548 |
Posted: 12 Jan 2017 at 5:07pm |
You can buy LED replacement bulbs for the 1196 backup light bulbs but they may not give off enough light. I had some universal round headlights on my B and found some 12V, 100W aircraft landing light sealed beams for them. Talk about putting out some light but the FAA said I had to file a flight plan every time I used them.
wbecker
Posted: 12 Jan 2017 at 6:03pm |
Maybe go to NAPA store and ask if they have an LED replacement bulb to fit the socket?
Joined: 11 Sep 2009 Location: illinois Points: 89201 |
Posted: 13 Jan 2017 at 3:25pm |
Normal head lights on a car are about 55 watts... at 12 volts, that's about 5 amps each bulb.......... I would take the original bulb and look at Auto Zone or other and match up a LED bulb with the same base.. If your not worried about original case, they do sell aftermarket lights with LED bulbs inside that you could bolt on inplace. If your question is, is it OK to use the 12 v LED, yes, any bulb would be OK... Somewhere around 55 watts.
