AC B Grill |
Post Reply |
Ted in NE-OH
Orange Level Joined: 12 Nov 2009 Location: Austinburg OH Points: 1703 |
Posted: 28 Mar 2012 at 12:19pm |
What id the best way to remove the grill screen from the sheet metal. It is spot welded and I need to replace it and get rid of the remains of the spot weld.
GlenninPA
Orange Level Joined: 11 Sep 2009 Location: Ashley, PA Points: 5054 |
Carefully grind off the mesh from the back side. If you got steady hands, use an angle or die grinder. If not, use a Dremel with a good grinding stone. The Dremel will take longer, but is not as likely to produce an "oops!".
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance. Wise men learn more from fools than fools from the wise. |
Post Reply | |
