AC B Front D Rings Mounted on wide Axle
SouthLouisiana121333 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SouthLouisiana121333 Quote  Post ReplyReply Direct Link To This Post Topic: AC B Front D Rings Mounted on wide Axle
    Posted: 24 May 2024 at 12:29pm
Hello everyone,
Wondering if anyone knows where to find the D rings that mounted to the front of the later B front axles? I’ve searched and can’t find anything! Pics attached for visual reference
Thanks in advance….
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2024 at 4:27pm
you think those were "factory" or someone built them ?  Looks like a "weld on D ring" welded to a flat plate... Anything you buy that is PRE MADE will have a strap thru the ring with a bolt on each side..
Edited by steve(ill) - 24 May 2024 at 4:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SouthLouisiana121333 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2024 at 8:47pm
I don’t know! I’ve seen identical d rings and bolt on plates like that on several different builds across Google and YouTube. Figured they may have been factory….🤷‍♂️
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2024 at 9:04pm
Don't think they are OEM. They are homemade.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SouthLouisiana121333 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2024 at 9:08pm
Thanks Dr. Allis
Aaron W in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aaron W in NC Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2024 at 3:57pm
Is there a purpose other than to tie the tractor down when hauling it to have the D rings on the front axle?
1963 D10
Post Options Post Options   Thanks (0) Thanks(0)   Quote SouthLouisiana121333 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2024 at 5:18pm
Well, I live in South Louisiana so although I don’t ever plan on getting it stuck, in the event that it would the attachment points up front would be useful in getting it unstuck. But they definitely make it nice to trailer as well.
Edited by SouthLouisiana121333 - 26 May 2024 at 5:19pm
rasman57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rasman57 Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2024 at 9:41am
This page was generated in 0.127 seconds.
