AC B Fan sheavs
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Topic: AC B Fan sheavs
    Posted: 10 May 2017 at 8:31pm
Anyone know a way to loosen up the sheave adjustment on the fan on the AC B. After 75 years things don't want to move. I am out of fan belt adjustment with the generator.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 8:36pm
On most it take removing the pulley and sing heat on the outside as you tap the center out. After the two bolts are removed. Wire wheel and sand it to get it to slide together.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2017 at 8:36pm
Get a shorter belt. I have 3 of those fan pulleys here. I had the best lookin one in the electrolysis tank for a couple days, soaked it in PB blaster, tapped on it with the wood hammer handle and gave up on it.
