AC 816 Backhoe Parts |
Gavineg123
Joined: 29 Jan 2021 Location: United States Points: 8 |
Topic: AC 816 Backhoe PartsPosted: 31 Jan 2021 at 12:12pm |
Where is the best place to look for backhoe parts? For example gauges, starter, transmission, and hydraulic parts? Also, best place to buy engine parts? It’s a Perkins inline 4 cyl. Any help is appreciated
gemdozer
Posted: 31 Jan 2021 at 1:30pm |
You could check with MINNPAR
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42238 |
Posted: 01 Feb 2021 at 5:36pm |
the AC 816 used a AC engine from my knowledge , the 715 used a Perkins 236 - 4 cylinder
Jim.ME
Posted: 01 Feb 2021 at 7:48pm |
816 and 816B parts books at Minnpar show Perkins.
Gavineg123
Posted: 01 Feb 2021 at 8:02pm |
I’ve got a service manual for it and it shows a Perkins 4.248 engine
Eric B
Joined: 09 Feb 2012 Location: British Columbi Points: 1009 |
Posted: 02 Feb 2021 at 12:17pm |
So many parts for the 816 are found in and on other industrial equipment. Therefore it helps to search the brands on each component rather than searching for '816 parts' as direct listings are simply harder to trace being they were made around 40 to 50 years ago. Like the starter for example if you get the number off of it you will have a much easier time tracking a replacement or individual parts. You can find gauges that fit but they may no have the AC logo on them. The forward reverser is a Borg Warner, the rear end is Rockwell, the hyd. pump is a Commercial Shearing, the engine being a Perkins 248 is not hard to find parts for as they were widely used in many applications.
david a
Posted: 14 Feb 2021 at 3:46pm |
had a hard time finding the steering pump. The shuttle is a WG. not a borg werner hard to find parts for. I rebuilt mine the forward clutch is hard to come by. The engine is a Perkins. The main hydraulic pump is a expensive one to rebuild. The shift cable is hard to come by. I sold mine last year for $5500. just got tired of the scavenger hunt. and the expensive parts.
Eric B
Posted: 15 Feb 2021 at 11:42am |
What model year was your 816? The two I had were made in 1970 and they both had Borg Warner forward reverser.
david a
Posted: 16 Feb 2021 at 8:01pm |
think mine was a 1975. and It was a werner gear shuttle . Had very big clutch plates.
Norris1606
Posted: 23 Nov 2025 at 4:39pm |
do you have any information on the steering pump/steering orbital? I just bought an 816 and the steering orbital has a crack in the housing. so far, Ive not found any numbers stamped or any tags on it. Thanks!
Coke-in-MN
Posted: 23 Nov 2025 at 11:32pm |
The orbital should interchange with many other tractors
AC used most parts from other suppliers rather than being AC only built . Starter motor is Delco though I just replaced mine from a Amazon supplier 10 tooth drive and full new unit was $140 - I had rebuilt mine 3 times over the years and have cracked 2 nose cones on the Delco units
Norris1606
Posted: 24 Nov 2025 at 4:44pm |
I figured the orbital would interchange, just not sure where to begin with not having any tags or stamped numbers on it. I was hoping someone had some info on the orbital as far as manufacturer or what it might interchange with.
