AC 8010 Power Shift issue |
RickA
Topic: AC 8010 Power Shift issuePosted: 18 Mar 2025 at 10:39pm |
While mowing pasture with my 8010 power shift the transmission pressure light came on. Tractor performance did not change so I assumed it might just be a wire or a sensor. Later the transmission temp light came on so I shut the tractor down. A few days later I ran it some more and both lights were on from startup until I shut it off. I took it to a local shop to have it diagnosed and repaired. They replaced senders for both lights and called to say all was good. While driving the tractor home, the transmission pressure light came on again. I contacted the shop and they came out to the farm today to check the transmission pressure. Not sure why that wasn’t done at the shop. Anyway, the mechanic called me to say there was no oil flow at the filter and the element inside was collapsed. They had replaced the element at the shop along with all the hydraulic fluid. He thinks the pump is bad but needs to think it over tonight. Does any of this compute with you all?
Posted: 18 Mar 2025 at 10:55pm |
No. He better think really hard. I have never seen a collapsed filter. WHICH filter?? Changing hydraulic fluid (your words) has nothing to do with the TRANSMISSION. Transmission oil is on the long dipstick and takes 7+ gallons to refill after you clean the screen under the belly and change the vertical canister filter. Hydraulic oil is the sight glasses and takes 17+ gallons after you change both belly filters and drain three drain plugs. Transmission filter is at the right rear corner of the tractor at belt buckle height. Hydraulic/differential filters (2) are under the belly that you lay on a creeper to change. This sounded like an electrical dashboard problem until the collapsed filter which still doesn't explain how the tractor moved at all if the pump is bad ?? He doesn't know..
RickA
Posted: 19 Mar 2025 at 4:20am |
My bad. Transmission oil, not hydraulic oil. The filter is the one you describe at the right rear corner of the tractor inside the large metal canister. I can’t understand how the pump could be bad either since the tractor moves and shifts normally. I’m not sure what to expect from him when he calls after he has thought this over.
Posted: 19 Mar 2025 at 4:25am |
He must have installed the filter wrong or the wrong filter and crushed it when using an impact on the draw bolt. I'm concerned about how much debris has moved from the collapsed filter into the Power Shift trans valve which may cause issues. The suction screen should be inspected and cleaned unless he did it when changing the trans oil. I still think it is an electrical panel issue.
Edited by DrAllis - 19 Mar 2025 at 5:54am |
RickA
Posted: 19 Mar 2025 at 5:15pm |
The shop foreman called today. They are concerned that the field mechanic could not get a good pressure reading on the transmission pump. They don’t think I should drive the tractor in its current state although I drove it 25 miles from the shop last week. They are coming to get it Monday and hauling it back to the shop for repair. I got the impression he thinks they did something while servicing the tractor that might be contributing to this issue. I shared your thoughts about the pump since it drives and shifts normally. He was respectfully insistent that they want to explore further and are making this a priority given that I need the tractor for planting in mid April. More to come and thanks for your input!
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2483 |
Posted: 19 Mar 2025 at 8:31pm |
I've seen some wiring problems on those tractors behind the cookie sheet. I'm referring to the heat shield panel behind the engine, at the firewall. The main harness is easily seen once removed.
Mikez
Posted: 22 Mar 2025 at 9:52pm |
Ask to see the collapsed filter and put picture on to show dr
RickA
Posted: 02 Apr 2025 at 4:40pm |
The shop foreman called today. They took the fuel tanks back off the tractor and after much research found that the inlet and outlet hoses to the pump were reversed. This is what was collapsing the filter. I’ve been running this tractor for three seasons and never had an issue until the light started coming on last fall. They did not catch this when they had it apart the first time. This time they also found a bad wire near the bell housing that was causing the light to come on. I suggested that maybe they switched the hoses when they were working on it last month but they said in order to right the situation they had to change out fittings to get the hoses back to the correct position. They want me to take partial responsibility and pay half the labor for the second trip to the shop. These people have been very good to work with over the years and I’m sure they run into many head scratchers working on these old tractors, but $12k later I’m wishing I would have just kept driving the tractor with the lights on and hoped for the best. Anyway, they assure me it’s a sound tractor and I am getting it back just in time to connect to the planter.
Posted: 02 Apr 2025 at 5:12pm |
I'm confused. I'm trying to figure out the whole story here and I don't think it's been fully told. It now looks to me like someone just recently had the transmission out of this tractor and went thru it ?? And upon reassembly they crossed up the two hoses that go to the Power Shift transmission filter ?? This collapsed the filter because of incorrect hose installation. Red light problems were wiring related, of which the wires in the bell housing area would have been messed with the removing and reinstalling the transmission. If I am correct here, they installed the hoses wrong and probably/possibly also caused the wiring problem. I wouldn't have the guts to send you a bill for that.
RickA
Posted: 02 Apr 2025 at 5:47pm |
I bought the tractor on Bigiron 3 years ago. The tranny lights issue came up last fall. I took the tractor in for diagnosis and repair in January this year. They put in new senders for the lights and said idling the tractor for two hours resulted in conclusion that the lights were fixed. While in the shop I had them put new spindles and bushings in the front end, bearings in the front wheels, a new shroud on the radiator and change all fluids and filters. Then my story with the transmission begins. I told them to check out the tranny first so I wouldn’t be spending money on a dead horse, but they neglected to check the trans pressure while servicing so never noticed the swapped hoses. The transmission filter was collapsed when they serviced in January. My bill for everything was $10k. When the transmission pressure light came on driving it home, they decided to come to the field and check the pressure. They could not get a pressure reading at the filter and noted it was collapsed again so they loaded it up and went back to the shop, got back down to the pump and that’s when they noticed the hoses were switched. Someone apparently had the transmission worked on before I bought it. They’re now asking me to pay $2k of the bill for the second trip to the shop which is 50% of the total labor bill.
Posted: 02 Apr 2025 at 6:22pm |
A collapsed filter and they just changed it?? and not investigating into WHY it collapsed ?? They can't be an old Allis/Deutz/AGCO dealership.
RickA
Posted: 02 Apr 2025 at 6:50pm |
Would those reversed hoses cause the collapse? That’s what they think caused it. As far as they are concerned the mystery is solved.
RickA
Posted: 02 Apr 2025 at 7:16pm |
I understand what you’re saying though. They should have investigated it the first time. Can’t explain that.
Posted: 02 Apr 2025 at 7:18pm |
YES !! the crossed hoses did indeed cause the filter to collapse.
Mikez
Posted: 03 Apr 2025 at 8:29am |
Dr. Should the transmission work normal with lines crossed and filter collapsed.
Posted: 03 Apr 2025 at 9:21am |
I would expect it to work fine, but zero filtering of the tranny oil.
Acdiesel
Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2592 |
Posted: 03 Apr 2025 at 11:04am |
I would be inclined to not pay the additional costs. How is it your fault that they did not further investagate the collapsed filter issue?
They had no problem figureing it out the second time. |
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF D15 SER.2 DIESEL D12 SER.I, D10 Ser.II 2-720'S D21 Ser. II Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3658 |
Posted: 03 Apr 2025 at 12:00pm |
Butting in, to be clear, there is no inlet or outlet hose TO the pump , there are lines from the pump to the filter and to the shift cover. The pump draws fluid from the screen in the bottom housing into the gerorter pump and then sends it to the filter. From there it goes to the shift cover to power the clutches at 230PSI the remainder of the oil goes to the cooler and then back to the cover at 14-16 PSI and THAT is what triggers the lube pressure light below 1800 RPM - if the lines were crossed , as Doc stated, it could have back flushed some of the trapped material into the shift cover. All this to say this is a stretch to have crossed the lines unless the metal lines were replaced with rubber.
Posted: 03 Apr 2025 at 12:31pm |
Yes, but all the 8000 series used hoses. It is still hard for me to figure out how they crossed the hoses, unless they were brand new hoses, because an old hose takes a "shape" to fit in the place it belongs....generally. Still there wasn't given any thought to which way they go. It was 50-50 and they got it wrong.
Mikez
Posted: 03 Apr 2025 at 12:42pm |
People will surprise you.
I pulled up neighbor farm and they were putting a new hyd drive motor in tracks on excavator. Fighting the heck out of the hoses complaining the hose is too short to reach. I said to myself they must be wrong. Next day was redoing the line as they were wrong
