AC 720 3 point hitch need advice |
Heliarc
Joined: 23 Jun 2019 Location: Shickshinny PA Points: 74 |
Topic: AC 720 3 point hitch need advicePosted: 30 Jul 2025 at 8:42am |
I don't know much of tractors. 3 points, even less. Eventually I want to run 3 point implements on my 720 but I have no links(?). I've heard of category 0 but I have no idea what that means and I have no idea what links to look for. Do I just look for category 0 links and those will be correct? Same for implements. Do I look for something like a category 0 back blade?Also this tractor doesn't seem to have those rock shafts to raise and lower a 3 point hitch. It has a stubby hydraulic cylinder so I'm lost how a 3 point would even hook up.
Edited by Heliarc - 30 Jul 2025 at 8:44am |
AcFordHawk
Joined: 12 Sep 2009 Location: Boone, IA Points: 248 |
Posted: 30 Jul 2025 at 9:59pm |
uploads/610/3pt_schematic_2025-07-30_21-52-45.pdf
Here are a couple of PDF pages from the Simplicity 9020 parts list I have - just the 3pt components. Sounds like you have the hydraulic cylinder and its attaching points which should also include the rock shaft - assuming you have the lift cables for the mower deck. The lift cables operate off the rear hydraulic cylinder. Yes, look for Category 0 implements. Generally, they use 5/8" diameter mounting pins.
IB (restoring), MF GC1705, MF 2705E
AcFordHawk
Posted: 30 Jul 2025 at 10:07pm |
How it should look assembled minus the middle third link and sway chains (limit the side to side movement of the lift arms).
Heliarc
Posted: 31 Jul 2025 at 9:15am |
I have the rear cylinder and associated hydraulics and a piece that bolts to the rear axle to keep my rear PTO pump from spinning but that's it. This 720 most likely had a 3 point at one time but now has a backhoe mounted to it. I figure the 3 point gear was removed so the hoe could be installed. I don't have a rock shaft, nor does it look like I have anything for it to even mount to. |
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3201 |
Posted: 08 Aug 2025 at 7:31am |
I have non runner that I'd sell whole or parts.Also an original loader and brush hog.
Jt s. candycane
Posted: 13 Aug 2025 at 9:56pm |
The brush hog 2000 rpm pto ?
Edited by Jt s. candycane - 13 Aug 2025 at 10:12pm |
Heliarc
Posted: 18 Aug 2025 at 6:35am |
What's your location? My loader is an ARC or ARK. I could sure use a parts machine. |
