AC 720 3 point hitch need advice
Heliarc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heliarc Quote  Post ReplyReply Direct Link To This Post Topic: AC 720 3 point hitch need advice
    Posted: 30 Jul 2025 at 8:42am
I don't know much of tractors. 3 points, even less. Eventually I want to run 3 point implements on my 720 but I have no links(?). I've heard of category 0 but I have no idea what that means and I have no idea what links to look for. Do I just look for category 0 links and those will be correct? Same for implements. Do I look for something like a category 0 back blade?Also this tractor doesn't seem to have those rock shafts to raise and lower a 3 point hitch. It has a stubby hydraulic cylinder so I'm lost how a 3 point would even hook up.
Edited by Heliarc - 30 Jul 2025 at 8:44am
AcFordHawk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AcFordHawk Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2025 at 9:59pm
uploads/610/3pt_schematic_2025-07-30_21-52-45.pdf
Here are a couple of PDF pages from the Simplicity 9020 parts list I have - just the 3pt components.  Sounds like you have the hydraulic cylinder and its attaching points which should also include the rock shaft - assuming you have the lift cables for the mower deck.  The lift cables operate off the rear hydraulic cylinder.
Yes, look for Category 0 implements.  Generally, they use 5/8" diameter mounting pins.
IB (restoring), MF GC1705, MF 2705E
Post Options Post Options   Thanks (0) Thanks(0)   Quote AcFordHawk Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2025 at 10:07pm
How it should look assembled minus the middle third link and sway chains (limit the side to side movement of the lift arms).
Post Options Post Options   Thanks (0) Thanks(0)   Quote Heliarc Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2025 at 9:15am
I have the rear cylinder and associated hydraulics and a piece that bolts to the rear axle to keep my rear PTO pump from spinning but that's it. This 720 most likely had a 3 point at one time but now has a backhoe mounted to it. I figure the 3 point gear was removed so the hoe could be installed. I don't have a rock shaft, nor does it look like I have anything for it to even mount to.
