ac 715 backhoe
Message Reverse Sort Order
Dave A View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave A Quote  Post ReplyReply Direct Link To This Post Topic: ac 715 backhoe
    Posted: 27 Jul 2010 at 4:28pm
Think Coke might have a better lead. these guys sometimes get used stuff in they also have a parts web
http://worthingtonagparts.com/
Play the game for more than you can afford to lose... only then will you learn the game.
Winston Churchill
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 9:13pm
Coke, You are one massive source of all kinds of good information!!!
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 2:43pm
Minnpar may have parts and there are a couple of other people on here with 715 parts also.
T19, Borg Warner
Parts
Borg Warner T-19 Heavy Duty four speed with a cast iron case
Ford Trucks 1974-85
Case casting number is 1309
Synchronized in all forward gears
Single step reverse idler gear
Edited by Coke-in-MN - 26 Jul 2010 at 2:44pm
LIAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LIAM Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2010 at 1:40pm
can any one give me a lead to where I can get parts for a t-19 transmission ? H ad a bearing fall in and i need a couple parts to rebuild it lost all but fourth gear. local guy said fifteen hundred to rebuild I would much rather buy a used trans for 1/2 as much . Don't plan on driving back and forth to work w/ her.
