AC 712H
modirt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote modirt Quote  Post ReplyReply Direct Link To This Post Topic: AC 712H
    Posted: 27 May 2023 at 9:19pm
Would not start, did some diagnostics and points were bad. Put in a tune up kit (plug, points, condenser) and that got us fire. Found nipples on fuel pump busted off, so replaced it too.
Will now start, run for a few seconds, then die. Will not continue running or power up....so apparently not getting gas. New fuel pump is pumping.
We drained out all old gas and replaced with new.
Time to pull and rebuild carb? Has been sitting for a couple years. Are carb kits even available? Kohler engine.
Doug Acord View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Doug Acord Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2023 at 11:23am
Yes rebuild Kits are available at most small engine dealer, that work on Kohler, the kit is the same from 8 hp to 16 hp
This page was generated in 0.119 seconds.
