AC 7060 fuel pump question |
Post Reply |
AC 426 power
Orange Level Access Joined: 01 May 2012 Location: Ohio Points: 514 |
Posted: 24 Jul 2012 at 7:58pm |
Went to start my 7060 and it would turn over but nothing but then realized that i had not pulled the injector pump shut off out but it still would not start then i primed the pump with the plunger and it took right off but sorta had a miss for a few seconds the tractor had set for about 2 weeks without starting as well. Is my pump getting weak or? Any thoughts ? If you have a question just ask thanks
Alan (C-IL)
Silver Level Joined: 07 May 2012 Location: Washington, IL Points: 117 |
Sounds more like air in the fuel resulting from a leak or bad check valve. The stumble was probably due to some trapped air in the lines. Do you see/smell any diesel fuel leaking?
AC 426 power
Edited by AC 426 power - 24 Jul 2012 at 8:28pm |
Alan (C-IL)
yea, diesel fuel systems don't like air and when you lose your prime, its a pain to reprime them... Sounds like you got lucky and it primed up easy. If you have a diesel leak, it is very likely that air is getting back in.
AC 426 power
MACK
Take the primer pump apart. There is 2 check valves that could have foreign materal in them not letting them seat. MACK
Post Reply | |
