AC 7030 transmission
Stanley View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stanley Quote  Post ReplyReply Direct Link To This Post Topic: AC 7030 transmission
    Posted: 16 Sep 2018 at 7:42pm
We acquired a 7030 earlier this summer and I am getting around to changing fluids. The tractor has lots of hours on it (tach hasn't worked for yrs) but seems to run very well. The tranny shifts okay and works fine. However when I took off the "screen cover plate" to gain access to the pump screen I found several metal pieces on the cover plate. Mostly small pieces (filings) but a couple larger ones. Larger ones are less than a 1/4". Due to the age of the tractor, the fact that the transmission works okay and also that we will probably use it less than 50 hours per year, I'm considering just putting new fluid in along w/ filter and see what happens. Does anyone have a different opinion?
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2018 at 8:21pm
Probably from prior failures. I would do just as you are doing... You have 3 trans/hydraulic filters = don 't forget to pull the plugs out of the 'belly' filters and reinstall in the new ones. The trans filter is a spin on...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stanley Quote  Post ReplyReply Direct Link To This Post Posted: 16 Sep 2018 at 9:28pm
Thanks for the reply. I did pull the other filters and replaced all 3. I'll ned to take out a loan to able to buy enough oil for the re-fill. LOL
Play Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2018 at 7:18am
I'd agree with tbran. I'd change the fluid and filters and run it.
When I was doing the filter changes on my new to me 7000 a few years back I found a whole bunch of big ugly in the sump. Based on the sealer on top of the transmission someone had obviously been in there.
When I bought the tractor the owner was 100% honest with what was wrong and what it needed, a transmission problem wasn't one of them.
A few weeks after I found the stuff I ran into the prior owner. First I stated very clearly that I knew I had bought the tractor as is, where is, and no matter how he answered I was still good with the deal and wouldn't be mad. I just wanted to know before I continued in case I needed to do some transmission work first. I told him I had found the big ugly when changing the fluid and asked if they had ever had any transmission issues. He said they had not and also guessed the original owner probably had and what I found was leftovers.
That was ~ 125 hours ago and everything works fine.
On a side note, the reason they took the tractor out of service was the PTO had started to slip. The hydraulic fluid I took out looked like a vanilla milk shake. I've only used the PTO for some light work since, but with new fluid and filters that too is working well.
Here is what I found in mine;
Edited by Play Farmer - 17 Sep 2018 at 7:19am
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2018 at 8:19am
That looks like a broken wave spring from PD.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stanley Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2018 at 8:38am
Play Farmer - That looks familiar, but I didn't have that much. Thanks
