AC 7020 Power Shift Problems |
AllisFord1987 ![]() Bronze Level ![]() ![]() Joined: 13 May 2019 Location: Missouri Points: 2 |
![]() ![]() ![]() ![]() ![]() Posted: 13 May 2019 at 2:47pm |
Was planting beans with our farms AC 7020 a few weeks ago and had power shift problems.
It happened when I backed the planter in a corner, then once I put it in 1st gear and tried to go forward, the tractor died. At first I thought I took my foot off the clutch too quick. So I tried again and the same thing happened. It will go in reverse and move just fine. It only happens when I try and go forward. It will move fine if put in neutral ( had to tow it out of the way). Any ideas? When cycling through the gears it seems to hang up on 5th and not go any further. Looked it all over from the outside and everything appears to be fine. Thanks |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21927 |
Now that it has cooled off, sit in the seat and shift from R up thru 6th several times. Start the engine and see if it is fixed. Something had the reverse clutch plunger stuck down. When was the last time the Power Shift oil AND FILTER were changed ???????????
Alvin M ![]() Orange Level ![]() Joined: 24 Jun 2018 Location: PA Points: 802 |
can't shift with foot clutch in to 5th or 6th pull power shift value and check control rack saw them brake and had some spools say in then it trays to go into two gears
bigal121892 ![]() Orange Level ![]() Joined: 05 Jan 2010 Location: Nebraska Points: 812 |
No need to push the clutch in, if the tractor is shut off.
