AC 701 wagon gear correct weight rating?
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Topic: AC 701 wagon gear correct weight rating?
    Posted: 09 Feb 2017 at 11:15am
I have been repacking my AC 701 wagon running gear's wheel hubs (part # 709). In doing so, I did an internet search to find it's correct 41461s hub seals. During that search, I repeatedly found this hub to be rated at 2,760 lbs each (so - 11,040 lbs for all 4 wheels - right?). If that is true, then how does this wagon running gear add up to it's original 7 ton rating? I am curious though. Did the original mfg over-rate it? Or, is today's engineering under-rating it?
