Unofficial Allis Homepage
AC 655 Shuttle Clutch
Randaleky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2019 at 10:55pm
if you checked pressure at the filter and only got 60 then it appears like problem is back toward the pump. I an wondering if the back end of the pump which is for the convertor side is driven by a keyed shaft and the key could be sheared ? I will look it up on my parts book and see . this is stumping me also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 05 Oct 2019 at 11:36pm
when the problem first happened after operating 30 minutes , did the hydraulics for the loader bucket loose its power ?
Big Jim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Jim Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2019 at 11:15am
the picture in the parts manual shows where it is.
Mikeys250 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikeys250 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2019 at 11:50am
No the loader hydraulics stay strong at all times.
I really think I’m gonna find this sump screen clogged and starving the pump for fluid. Since I had 150psi and I drained the fluid and I dropped to 50psi I think more settled on the screen when the fluid was drained.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2019 at 4:41pm
My parts manual for the HD4 shows the screen assembly to be in line just short of the bend in metal line where it turns down to the sump. My HD 4 dozer does not have a screen in the line . I think many screens were eliminated by the owners . Might be some type of screen in the tube attached to the sump pan.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikeys250 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2019 at 6:05pm
The way I’m looking at mine it looks like it’s either bolted to the bottom of the rear compartment or inside the compartment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Jim Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2019 at 6:06pm
If you go down the line to the rubber hose. The hose goes on the cover asy.
The cover is held on with 8- 5/6 bolts.                                          the screen is inside.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikeys250 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2019 at 6:20pm
So I’m gonna loose all the fluid when I do that correct?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Big Jim Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2019 at 6:33pm
I hate to tell you, yes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2019 at 9:27pm
should be a drain plug on bottom of torque tube . use a plastic drain pan to save the fluid .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikeys250 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2019 at 11:30am
Ok folks. I haven't made it the sump yet but I have another question yall might can help me with.
Does anybody know of a boneyard or anything that might have used loader buckets that will fit this tractor? Once I get it all running right I would like to put a 4 in 1 on it since its already plumbed for it.
NomoreJohnDeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2019 at 8:30am
HD3
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2019 at 9:17pm
Blount used parts, Hoboken, GA. HTH Tracy
Liberals should know this by now. Voting for Obama the first time was ignorant, voting for him the second time was just stupid.
