AC 653B Dozer
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Topic: AC 653B Dozer
    Posted: 05 Apr 2016 at 6:07pm
Guys:  Have been researching for some time now on the 650 series, I saw one picture on the internet of a 653B inside pushbeam dozer.
Questions - Did AC go with the B series for all of the 650 machines and if so were there any refinements over the 1st series. Am wondering if any members have any 650 B series?
Am assuming the 650 B series must have been very late 74 or 75 production
Thoughts and comments appreciated.
Thank- you...Orangeman
Edited by orangeman - 07 Apr 2016 at 3:17pm
albatros_3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote albatros_3 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 2:11pm
I didn't know there was a 653B machine. I have a 653 and everyone I see seem to be the same. Is there a visual difference between the 653 and 653B, like decals?
Randaleky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 2:21pm
I would love to see one also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 3:15pm
Albatros and Randaleky -  I don't know how to post pictures here but there is one on the net if you do a google search for Allis 653B it will come up.
The 650 series and 653B in the image look the same outwardly.   Did they have engineering updates for the engine and torque converter?  Since the 433 DI had improvements in the front thrust bearing area see discussion on the 6080 in the farm section ~ was it possible that they improvement on the farm application for the engine found there way into the 653B.  What other things could have been updated - who knows, thus the post and my inquiry.
Thanks guys!
Orangeman
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 9:24pm
I googled the 653b and saw the one you mentioned. posted in 2009. I do not really see any difference with the 653 unit.  looked good. had 653b on side of hyd tank in pic. is this the one you saw ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randaleky Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2016 at 9:42pm
i sent pics to tracy martin to post them here. i do not know how either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 08 Apr 2016 at 4:09am
Yes- 653B is located on the side of the tank.  It was a very nice looking machine!
Post Options Post Options   Thanks (0) Thanks(0)   Quote albatros_3 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Apr 2016 at 6:54pm
That is a good looking machine. I'd like to get mine looking that good one day. As for the engine, I wouldn't think the thrust bearing would be an issue in a 650 machine since the 6080s problem related to the clutch and pto clutch. Those clutches ended up applying a lot of force on the crank and at startup on a cold engine doesn't turn out well. Now that's not to say there couldn't have been upgrades. Either way, a 653 is a good little machine.
Craig/insoh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig/insoh Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2016 at 11:59am
I don't think a 650 series would be affected by that engine upgrade it didn't happen until 1983 or after pretty sure fiat was not building the 650 series at that time!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Craig/insoh Quote  Post ReplyReply Direct Link To This Post Posted: 13 Apr 2016 at 12:04pm
Serial number is on nose of machine at front of machine look at the grill look down numbers were stamped on the frame sticking out from under grill! My dad has a 652!
