AC 621 forklift engine options
Jerryh770 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jerryh770 Quote  Post ReplyReply Direct Link To This Post Topic: AC 621 forklift engine options
    Posted: 17 Dec 2017 at 9:36am
Hi guys, I have a 621 forkluft with the 160 gas engine that has coolant in the oil. We took the head off and had a machine shop ccheck it, checked out good. Head gasket looked good. There was coolant in number 2 and 3 cyls. I' curious if a guy could swap a diesel in without too much trouble, and if so which one would be the best to consider? I'm interested to hear what you guys think. Thanks in advance
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2017 at 9:51am
Anything is 'possible' though IF you go diesel be sure it's a GOOD engine ! I was quoted 5,000 Canucks to have the Buda BD153 rebuilt ONCE I got it to the repair shop.
I considered going to gas but 'details' like need gas tank and fuel pump, wiring, etc. come into play...then there's 'step two' of the swap... remove 4000# counter balance from forklift....sigh...
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2017 at 10:10am
Son just had a chance to pick up 20 fork trucks from place in Mpls - older units with little or no resale - few have had mast stripped and such -  outfit sold or gave away over 75 trucks in last year or so to another employee that had room and ability to make a small salvage yard operation - he says he is full now and can't take more units .
 So now have to Yale fork trucks somewhere here and 2 counterweights laying out by drive as they had to come off to load the units onto trailer
 ( Seems I mumbled something like when you get your own place you can collect all the junk you want ) somehow I wonder if that was heard
Edited by Coke-in-MN - 17 Dec 2017 at 10:12am
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 17 Dec 2017 at 10:34am
Recommend pulling the block - might be time for an overhaul.  Pull oil pan and check for leakage between the liner and O'Rings that seal the liner to the block.
Orangeman
This page was generated in 0.123 seconds.
