AC 620 front timing marks? |
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10936 |
Topic: AC 620 front timing marks?Posted: 20 May 2017 at 6:34pm |
I have a 616 that has a 620 engine in it. On the front of engine, there is a indicator that has a mark to set to mark on front clutch. The Simplicity manual shows these on the 4041 .It doesn't clarify where to align the marks up at timing. I know it should be 20 degrees before TDC using rear engine marks. I don' want to use them because of all the stuff you have to remove. Any help appreciated. Thanks tracy
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4078 |
Posted: 22 May 2017 at 9:13pm |
dont you time that there the timing hole on the blower houseing
coggonobrien
Joined: 14 Nov 2010 Location: Eastern Iowa Points: 1890 |
Posted: 23 May 2017 at 8:24am |
Tracy, I just timed mine by ear. starts right now and seems to be fuel efficient.
Tracy Martin TN
Posted: 23 May 2017 at 8:41am |
There is a set of marks on the front of the 19.5 Onan. I got the info to align the marks from the Simplicity guys on facebook. Mine seems to have valve chatter in a hard pull uphill. Not sure if it is timing or valves need adjusting. Tracy
