AC 6080
42324232 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 42324232 Quote  Post ReplyReply Direct Link To This Post Topic: AC 6080
    Posted: 13 Jul 2025 at 8:28pm
Range stuck in low.  Is there a diagram for the linkage somewhere?  Any advice was working fine then wouldnt shift.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2025 at 7:11am
42324232, Welcome to the AC forum. Try this agcopartsbook link & scroll thru it to drivetrain transmission to view parts schematics.
https://parts.agcocorp.com/us/en/apbsearch?q=agcoallis/79005853/l&name=6080+TRACTOR
If for any reason link or site gets indifferent. You can start over on it homepage by clicking “parts book” icon. Then enter “6080” for model. Then choose 6080 parts. Then choose drivetrain again.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2025 at 1:59pm
Maybe this will not be the case - but in the past had one run w/o oil in tranny and planetary syncro was  seized ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 42324232 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2025 at 3:47pm
hooked up implement got back in and wouldnt shift into range got beneath tractor and got it shifted but cant get it shifted again.  linkage has a problem.  Range shift arm is not attached?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2025 at 4:03pm
The 4-speed lever and the RANGE lever are built into the shift cover on top of the transmission. There isn't ANY external shifting linkage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2025 at 5:18pm
Had that problem once - but bought one that had been setting , spraying a bunch of penitrating oil down the rubber boot, seems the shifter just needs lube
Edited by DougG - 14 Jul 2025 at 5:19pm
