AC 6060
WNYBill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WNYBill Quote  Post ReplyReply Direct Link To This Post Topic: AC 6060
    Posted: 24 Jun 2016 at 8:50am
Did some research here on a 6080 4WD that I passed on.  Now I am looking at a 6060 2WD.  These are the things I've learned.  Thrust bearing is not as big a problem on 6060, smaller clutch, so position of PTO clutch lever is not as important, still best if forward or engaged.   8 speed transmission may be a drawback, too big a jump between 4L and 1H.  May be cold blooded.   Many say this is the best engine Allis ever made.  I understand the rest of the tractor is Fiat.
How many hours before a major?   How is traction with 28 inch rear? Anything else I should look for? Or other shortcomings?  Good condition value?  I am thinking $6-7K?
Thanks,
Bill
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2016 at 9:00am
Dad has had his since new ('81)
Fuel Pump had to be rebuilt as the o-rings deteriorated inside.
Otherwise it has been reliable but we only have 2000 hours on it.
Clutch needs to be replaced but dad does leave his foot on the pedal.
Brakes are strong
3 to 4 is synchronized. Otherwise gearing is OK, but we still wish for a PD.
Steering is easy
Cold blooded as heck. Wish it had preheat.
Good on Fuel and the motor is pretty dang strong.
Ours is not rear weighted but works fine with 3-16's or 10' disk
Front gets light, you need a rack of weights if using 3 point planter or other heavy implements.
exhaust is way tall and snags every freakin tree out there.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2016 at 9:04am
Pic for reference
Charlie
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2016 at 9:21am
Hours before a major cannot be determined.  Everyone uses and maintains their tractors differently - These factors determine the engine's lifespan better than the number of hours on the machine.
6060s were the weak sellers of the line due to the 8 speed transmission and 28" tires.  If you are not in a hurry, I would keep holding out for a 6080.  Depends what kind of work you will be doing with it.  Keep in mind, some 6080s did come with 28" tires, don't ask me why...
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2016 at 1:43pm
You've got me wondering, what's wrong with 28" tires? Work good on a bicycle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WNYBill Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2016 at 2:10pm
Leon....  big tires = big traction = more clearance.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2016 at 5:04pm
14 mph  :-(
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2016 at 7:34pm
I can chime in on 6080 longevity. We have 2 the '85 developed a hole in a sleeve at about 7000 hours and the '84 I had rebuilt at around 8000 hours. The '84 was still doing decent but like how the other one started with a rebuild so I had that one done as well besides I felt I was on borrowed time.
kev/ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kev/ont Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2016 at 7:52pm
We had a 6080 that we traded with 9800 original hours on it. It had a coolant filter that we changed religously every year. That engine worked as good the day it left as the day it came.
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2016 at 10:20pm
Traction is fair with 28" rears. Just hit 5000 hours all original although pump will need rebuild soon. My biggest complaint is the gear selection and the 2 shifters. Not enough forward gear choices and reverse high range is stupid fast and reverse low range is too slow. They have about 10 safety switches (give or take) and if they don't all agree with each other they can cause electrical issues. Many people just bypass them although unsafe I guess. Even with all my complaints I do like the tractor and they are pretty tough little units.
Post Options Post Options   Thanks (0) Thanks(0)   Quote WNYBill Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2016 at 7:40am
Nobody answered my value question.  It is not as nice a Charlie's picture.  The seat is shot and it has <5000 hours.  Tires are 50%?   We are getting ready to go look at it.  Will probably have some more questions.  Several on Tractor House for $6500, so I am thinking $7K tops.  This is Ford and JD country, so the Allis will be hard to move if it doesn't work out.
Bill
Eddie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eddie Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2016 at 8:05am
About all I do with this 6060 is mow with a 10' three point hitch cutter. It handles great and is very easy to maneuver, very nimble. Has 2800 plus hours and doesn't leak or burn oil.
Allis Chalmers 6060
10' Howse Rotary Cutter
5' Tiller
5' Box Blade
4' Aerator
Ferris Zero Turn Mower W/10' fold up sprayer
John Deere 455 Lawn Tractor
John Deere 955 w/loader &
60" belly mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2016 at 8:16am
Value I am not sure, I haven't seen many for sale.
It will do everything a new 60 HP will do but cheaper.
Charlie
This page was generated in 0.191 seconds.
