AC 6060 PTO Problem
Message Reverse Sort Order
AC Nut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC Nut Quote  Post ReplyReply Direct Link To This Post Topic: AC 6060 PTO Problem
    Posted: 04 Jun 2012 at 9:17am
What I failed to mention in my first post (my PTO doesn't engage), is that when I first started it up on the baler, I wasn't accustomed to the two lever PTO engagement process. I think the right handle was in "engage" mode when i pulled up the left shaft it ground a little like I was switching a gear w/o the clutch. I assume I sheared the bolt on the bearing forks?
This page was generated in 0.291 seconds.
