AC 5040 |
kwmck1959 ![]() Bronze Level ![]() Joined: 20 Jan 2017 Location: Northern Ca. Points: 2 |
![]() ![]() ![]() ![]() ![]() Posted: 20 Jan 2017 at 5:57pm |
I was recently given a AC 5040 and I have oil/water mix coming from an area behind the starter. When I pulled the inspection plates off the bell housing it was filled with this oil water mix....any ideas how or why it would have gotten in there ? I took out one of the bottom 4 bolts underneath the housing and the mix drained out but not sure what to do next about cleaning and removing all the mix from around the clutch/ pressure plate without separating the tractor....any thoughts or suggestions would be appropriated.
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54182 |
Oil and water, or oil and coolant? I'd check the dipstick, or drop the pan, and see what the bottom of the motor looks like first...
