AC 5020 Injector Pump maintenance
mhenke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mhenke Quote  Post ReplyReply Direct Link To This Post Topic: AC 5020 Injector Pump maintenance
    Posted: 24 Jul 2024 at 11:12am
Trying to identify the Fill, Check, and Drain ports on the injector pump from an early 1980's AC 5020..  The injector pump doesn't look exactly like the one in the OM or SM.
Information injection-pump assembly
Diesel Kiki
NP-PES2K65C210RS21
BOSCH 9 400 616 424 9400616424
ZEXEL 104302-6670 1043026670
TOYO-SHA 22815101020 22815101020
jwalters16 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jwalters16 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2024 at 12:04pm
Very bottom of second pic u see to phillip head screws bittom is drain then top left corn next to drain is the fill level screw. Only takes alittle oil
Post Options Post Options   Thanks (0) Thanks(0)   Quote mhenke Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2024 at 2:07pm
Just to clearify:
Post Options Post Options   Thanks (0) Thanks(0)   Quote jwalters16 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2024 at 2:51pm
Yes that is correct
