AC 5015 tachometer cable
Tommy2x View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tommy2x Quote  Post ReplyReply Direct Link To This Post Topic: AC 5015 tachometer cable
    Posted: 02 Dec 2025 at 8:20am
I am a proud new owner of this little beast. Was in great condition and low hours. I read up on them a bunch before buying and know that parts are very hard to get. Has anyone figured out an alternative to the 24 inch Tach cable. Mine is broken and would like the gauge to work so I can monitor hours and RPM. If there is an alternative I won't start sharing all of my "ideas".
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2025 at 6:54pm
Talk to Haim at Star Speedometer in Fl, he may be able to make you one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2025 at 8:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tommy2x Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2025 at 4:04pm
I found an old new stock speedometer cable on ebay. It has the square end i need and is 24 inches. It is also the same cable diameter. I was able to remove the end fitting from the old cable and reamed it a bit to push out the crimps. Once I get the new cable, I'll cut to correct length and try to re crimp the end piece back on. Wish me luck... Will post an update if it works.
