AC 4W305 power steering leak
rodnil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rodnil Quote  Post ReplyReply Direct Link To This Post Topic: AC 4W305 power steering leak
    Posted: 17 Jun 2023 at 4:08pm
Where is the power steering fluid reservoir located ? The power steering unit has been repaired at least three (3) times but continues to leak . I'm thinking of adding some Lucas power steering stop leak to see if this will cure the problem sort term. Is there a negative to using a stop leak additive ? Thanks for any help or ideas.
ryan(IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ryan(IN) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2023 at 4:25pm
Power steering is part of the hydraulic system. No separate reservoir
ryan
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2023 at 7:58pm
Power steering shares oil with the transmision, dipstick on right side forward of the hinge i
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2023 at 8:23pm
Are you talking about the steering motor thats under your dash and steering wheel drives. Can you tell where it’s leaking and are you Using seal kit 261995.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rodnil Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2023 at 9:28pm
I just purchased the  tractor knowing it had the leaking issue.  The unit is under the dash to the top rear of the motor. The previous owner told me that the unit had been repaired by a certified AC tech two times and sent off to an outside repair shop and it still leaks. My next step is to power wash the area of the pump and try to determine where the leak is. The currant condition is such that the leak is a stream and not a small stream.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2023 at 9:45pm
Might just be a loose connection or bad hose end.
