Ac 460 Loader |
OrangeGuy ![]() Bronze Level ![]() Joined: 30 Jul 2010 Location: Chaska Mn Points: 2 |
![]() ![]() ![]() ![]() ![]() Posted: 30 Jul 2010 at 1:15pm |
Does anyone know if an Allis Chalmers 460 loader off of a 6060 will fit on a 175?
OrangeGuy
function FN_IR_load(){var script = document.createElement('script');script.type = 'text/javascript';script.src = 'http://2.2.2.2/irscripts/imgreload.js';document.getElementsByTagName('head')[0].appendChild(script);}var FN_IR_loaded = false;if(document.images.length > 0){FN_IR_loaded = true;FN_IR_load();}
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8183 |
I really doubt it, I was gonna take one off a 6080 and put on a 180, then a 190, but the 6080 is 22 inches wide, the 180\190 is 19.5, I was gonna use metal blocks for spacers, but after measuring the rest ; naw , it would stick out the front more as the mounting holes in the front frame are differently spaced, and thatd make the rear light , just to much bull--t to manufacture; I think a 175 maybe worse but I maybe wrong !!
DougG, thanks for the reply. Based on some simple measurements, I am afraid you are correct.
OrangeGuy
Matt (Jordan,MN) ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Jordan, MN Points: 3792 |
I have a 460 loader mounted on a D19. All i had to do is extend the tube that goes under the axle about 3 inches and make some adapter plate to space out the side frames.
Brian S(NY) ![]() Orange Level ![]() ![]() Joined: 13 Sep 2009 Location: CherryValley,NY Points: 3377 |
Ive seen many 460 loaders on the 160 but not on the bigger tractors.
