AC 45 grader Steering Parts
Ian Beale View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ian Beale Quote  Post ReplyReply Direct Link To This Post Topic: AC 45 grader Steering Parts
    Posted: 20 Jul 2013 at 4:10pm
I ran into "parts not available" while repairing the steering box of our Allis 45 grader.  A local supplier was able to cross reference most of the bearings for me.  So for the record
Item
Part #
Quantity
Description
11
081677
1
BUSHING, steering shaft (bronze)
Lathe job
12
081707
1
BEARING, needle, steering shaft
Torrington B 3424
13
074962
1
SEAL, dust, steering shaft needle bearing
Standard industrial
3
076971
1
RING KIT, cylinder piston (4 phenolic rings and 1 rubber)
Likely standard parts
8
083186
1
PACKING ASSY, piston rod (5 rings)
19
080298
1
BEARING, needle, steering arm shaft
IKO Nippon Thompson
BR 405224 (written NGS 4024)
20
080297
1
SEAL, oil, steering arm shaft
Standard industrial
47
096843
1
BEARING, needle, steering shaft, upper
Torrington B 2212
26
80311
1
ARM, steering
Useable
Item No refers to the Allis parts diagram.
We won't talk about  the time to rebuild the tapered spline on the bottom of the steering shaft, which seems to still be holding up.
