AC 440 tractor
RUSS-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RUSS-OH Quote  Post ReplyReply Direct Link To This Post Topic: AC 440 tractor
    Posted: 01 May 2011 at 9:20pm
I am working on a 440 it has a Dana A235 axle. I need the sun gear and the stack nut for the plantary.
Dans 7080 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dans 7080 Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2011 at 10:34pm
You may want to look at a Steiger Bearcat. They are the same thing just different colors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RUSS-OH Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2011 at 10:33pm
Thanks for the info. I have found a place that has sun gears on order. Hope to get a hold of one. The stack nut is still a challenge. Still looking.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 7:40am
3 or 4 different companies used the same model, just rebadged. I have a book at home on them
Charlie
lussetto View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lussetto Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 9:44am
Might try this link.  I believe they are commonly reffered to as a Franklin planetary that most of the tractor pullers use.
Greg
Post Options Post Options   Thanks (0) Thanks(0)   Quote RUSS-OH Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2011 at 9:11pm
bigtractorparts.com was very helpful and shipped the parts I needed. Thanks to all.
This page was generated in 0.176 seconds.
