AC 433I electric shut-off
Eric[IL] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eric[IL] Quote  Post ReplyReply Direct Link To This Post Topic: AC 433I electric shut-off
    Posted: 06 Apr 2011 at 10:21pm
Today, my AC 433I diesel engine in my forklift unexpectantly shut-down.  I tried to restart it.  It turns over, but there isn't any light colored exhaust smoke.  So, I think it is not getting fuel?  I checked the electrical line going to the fuel pump shut-off solenoid and it was getting power when the key was in the run position.  So, I am assuming that somethings wrong in my fuel pumps solenoid shut-off?  What should I look for?  What is the procedure to dis-assemble these?  Thanks in advance for any advice.
Slade (TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slade (TN) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 8:42am
Injpumped could help you here I think....he posts on here frequently, maybe he will see your post...
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2011 at 10:06am
take out the 3 screws that hold the top cover, that will give you access to the solenoid. test it first, using a jumper wire, put 12v to it while listening close to see if you hear the click. good luck, Ed.
