AC 426 Power Directer |
BKarpel
Joined: 27 Apr 2012 Location: Collinsville IL Points: 115 |
Topic: AC 426 Power DirecterPosted: 03 Aug 2013 at 4:54pm |
What would have to be done to make a power directer hold up pulling 9500 hot farm. We can run a P pump, 466ci with a water to air intercooler at 3000 RPM or just water injection at 3250 Rpm. Will have to get a sfi clutch and flywheel built. Do the power director input shaft twist like stock D21? Does the floor high low shift good under a load. I have heard of straight shafting that but dont know anything about that. Can the transmission gears be chaged to get faster?
Edited by BKarpel - 03 Aug 2013 at 4:56pm |
Posted: 03 Aug 2013 at 6:23pm |
Where I come from, the class is identical and is allowed a 3" x 3" slotted (Precision brand) turbocharger. All the best ones are making 1,000 HP or a little better. They are running 20.8 x 38 rear tires and in a gear that is faster than a 7040 PD roadgear. The best PD clutch AC made was in a late-model 7580 4WD. It had 5 discs in low side and 3 discs in high side. I believe that it could be made to shift on-the-go (with valving changes) and hold the 1,000 HP. I don't believe that you could ever make it last very long with a standing start at 3,000 RPM in a gear faster than 5th (roadgear). That particular wet-clutch design will only stand so many degrees of heat and "bam" it will have warped components on the low-side clutch. it's kind of like wax or solder.....now you see it....now it's melted. Changing to a good multiple-disc dry clutch on a steel flywheel will last long and take the punishment. You'd need to design some sort of an input shaft to connect the flywheel to the high range input shaft in the transmission and then to seal off the clutch cavity from tranny oil. You'd also need a throwout bearing/linkage set-up, or maybe consider going to a Crower style RPM activated clutch. The range transmission gears in a Power Shift tractor are 20% faster than a Power Director tractor, so that would be a good place to start....a Power Shift rear end from a 7045 or 7060 tractor, as they have the fastest gear ratio final drives and range transmission. Your engine configuration (inj pump, injectors, turbo, camshaft grind, camshaft timing, etc, etc, etc) needs to be tailored to be able to "lug" really well, because you don't have an on-the-go feature. Get out your check-book and I'll help you spend it !!!!! |
BKarpel
Posted: 03 Aug 2013 at 7:31pm |
Can you explain how the power directer works? We had a 7000 when i was a kid and only rember 2 bottons on the floor( high and low). Do you know if Jared Nussbaum 7030 Gutless General is running a power directer? Would a D21 or 210/20 be a better transmission and rear end? Thanks just trying to add color to the class.
Posted: 03 Aug 2013 at 7:50pm |
You didn't have a "7000" with two buttons on the floor......you had a 7010 or 7020 or 7030 or 7040 or 7045 or 7050 or 7060 or 7080. I do not know for sure what the Gutless General is....there are many D21's 210's and 220's that get newer sheetmetal grafted on them. They also have more pulling parts available when it comes to trasmission parts versus the 7000's series drivelines.
O.P.S. Heads
Posted: 03 Aug 2013 at 8:50pm |
Nussbaum's is the 7030 that was at Gordyville and place second out of a bunch of hard running limited pro stock tractors. I think it's Brad Howell's old driveline from his diesel super stock day's. It is a 7030 driveline, but no way it has the P.D. still in it.
BKarpel
Posted: 04 Aug 2013 at 11:12am |
How does a power directer work? What would it take to straight shaft one? Do you have any experinece on water injection. Going to run D 21 intake mainfold and inject in cross over pipe. |
