AC 426 cast molds?? |
Mark D. ![]() Silver Level Access ![]() ![]() Joined: 14 Sep 2009 Location: Ubly, MI Points: 215 |
![]() ![]() ![]() ![]() ![]() Posted: 26 Dec 2010 at 11:37am |
Here is a question for the ole' Allis historians...
What ever happened to the old cast molds used to make the 426 heads and blocks?? Does anyone out there still have them?? Are 'OEM' replacements available from AGCO and did they cast them or are they left overs from 1985?
Thinking out load from the high-performance tractor pulling stand point. Hypermax Engineering is casting their own blocks and heads that have become "tractor pulling" legal replacements for the IH466.
Are there anyone out there capable of doing the same for AC???
Miss Behavin - D21 Super Farm
Xcessive Tinkering - 190 XT Hot Farm Puller Watch on YouTube - http://www.youtube.com/watch?v=J2TX1Af7aoA |
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8357 |
I have thought bout this too ; I believe all of AC, S stuff at Harvy was sold to a engine builder in Colorado, but then they also went out of business ; AC had a factory in France building engines and componets ; I,d say they are gone too ; you hear more of folks doing there own block ,and heads ; I,m sure itd take a buch of mooola but it could be done I,m sure l ; AGCO,S replacement for a 426 I think is a 466 or 40 series Detroit engine ;
Gary(WI) ![]() Orange Level ![]() Joined: 27 Nov 2009 Location: WI Points: 1005 |
what do you need to change to make it better there seem to be plenty of blocks out there for reasonable money I have 5 or 6 that I would sell for cheap Gary Roidt
Steve M C/IL ![]() Orange Level ![]() Joined: 01 Jul 2010 Location: shelbyville IL Points: 691 |
Ain't they known for splitting right down the camshaft when you make BIG hp with a million lbs of boost?
smuggler ![]() Silver Level ![]() Joined: 23 Dec 2009 Location: western ny Points: 325 |
Mark Gettinger is or was casting 426 heads that flowed big numbers. To steve m ive broke alot of blocks but never had 1 break near the cam but then we dont make alot of boost around 100 max usualy been up to 120 before but that wasnt planned lol
DaveKamp ![]() Orange Level Access ![]() ![]() Joined: 12 Apr 2010 Location: LeClaire, Ia Points: 6072 |
The DT466 breaks right along the camshaft line. Needs more meat in there to withstand the compression-power stroke of the cylinders.
wi50 ![]() Orange Level ![]() Joined: 24 Sep 2010 Location: weegieland Points: 1010 |
a couple nights agoe I stopped by the neighbors shop, the winter project is a couple new chargers, useing 2 of the existing chargers and new plumbing. Putting tie bars on the cyl head to the girdle to keep it togather enough to keep the sheet metal on if things let go. It's still an IH block at smaller displacement, he'd like a Hyper block but the cost is high, cheap though if the IH lets go.
The Hyper head is about $13000 and the block is 12 or 16K, a good share of that is R&D. I can't imagine how much time and money was spent over the years developing a part for such a niche market. I have no idea how many are made but I bet only hundreds, not hundreds of thousands like the OEM. Once you get to the point where you need the Hyper head and block, money probably isn't much of an object.
A few years ago I made a little trip over to the Tomahawk foundry, they were more than willing to make a head casting and the cost was not that high. I'd supply them with an original head and they could make me a solid one, or put intake and exhaust ports in one with little trouble, cores could be made and positioned in the mould. For our tractor pulling rules we had to use an OEM type head, they don't care what you do but it has to appear right. I've been working on an alcohol engine now and then for a while and holding coolant is no concern. I never did have a head made, but it may not hurt to go check in again on getting a couple rough castings made it's only about a half hour away for me.
Nothing is impossiable but some things to take longer.
Edited by wi50 - 26 Dec 2010 at 11:35pm |
The hyper block isnt in destructable they have alredy blown 1 that I know of apart . The block should have never been allowed in the rules. But a certain few big shots in NTPA kept whineing until they got there way, Even boycotted a whole season until the block was allowed. The hyper block actually has a Part # so it is supposed to be able to be orederd from any case IH dealer. And know you can run any block with any sheet metal in the super and prostock classes with a component chassis. Not a favorite rule of mine.
I don't think the Hyper blocks, heads, etc should have been allowed either, but it is what it is, it singles out a certain brand. Same as the fight with alky, diesel. Now region 3 will have a seperate heavy diesel ss class, my neighbor was fired up and plans on traveling to more this summer. I hope to get time to help with the tractor and traveling some, but summer spare time is not abundent to me.
Aren't there heads out there for JD and IH, Moline blocks and Olliver manifolds in the antique and classic tractor pulling arena that are new production, not OEM? Maybe not right either.
I talked to the foundry this morning and tomorrow I'm heading over to see what it would cost to make a head blank.
what kinda head blank are you looking for?
We have a Mark Gettinger head on our superfarm now. Problem is that you need to take a OEM head and get the water journals filled with hardblock. Over time, the cast from the head and the hardblock doesnt expand and contract the same with heat and therefore start to leak air.
What would be nice... is to have a head casted from new without water journals in it. This way, it would be solidly made from all the same material and should hold up much better with no leakage.
The block would be a bit harder. To make it stronger you would be adding material to the outside and therefore not using the same OEM mold.
Ive never seen 1 of marks heads he said they flow pretty good air. But they werent cheap. I think u can have a billet head made just as cheap but then again you cant run that in the super farm class
Gerald J. ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
Technically speaking cast iron parts are made from molds but the molds are destroyed getting the part out. Those molds are of treated sand, formed around patterns which are the pieces that are reused. Internal cavities are formed from cores usually made of sand glued together with supports to fit the mold. The basic pattern includes extensions for the core supports in the sand mold. Cores are also destroyed getting separated from the casting. Cores are created in "core boxes" which are molds to shape the core. Core boxes need to go along with patterns for a particular part and are reused.
The pattern has to include accommodation of metal contraction, often 5 to 10% in all dimensions. You can't take a metal part and use it as the pattern to make a replica, because the replica will be smaller due to that shrinkage. You can only use the metal part to make a wooden or plastic pattern (metal patterns can be used for high production parts, but wood is the traditional material) that is enlarged to account for the shrink. The casting foundary and the pattern maker have to work together because shrink is not always uniform and can depend on where the sprues are attached for pouring and details of the part shape. Any wood worker can make a pattern when given the basic rules of casting, but the part that results may not be exactly what somebody expected. With today's CNC mills, it probably is more cost effective to carve very snall quantities of engine parts from solid chunks of metal, but they are obviously not the original factory cast parts becuase the machined surface will never match a sand cast surface. Gerald J. |
I went to the foundry to make a solid head casting. A little wax buildup on it and some work to make some cores for the spark plug pockets. To make the mold and cast the head is a few week turn around, and the price isn't bad. In 2 to 3 weeks I should have a head blank ready for machine work. It just needs to look OEM, it doesn't have to be right, but it does have to look right. To make a perfect cylinder head, one would change a lot of things, but I bet we can make a really good head and maintain a stock apperance.
I wrote the check to make the first blank, it makes a little diffeence on the amount of work and the final weight, but a few hundred bucks would more than cover it. Edited by wi50 - 30 Dec 2010 at 2:59pm |
Mark D, do you have a stock ported head from mark ?or do you have a aftermarket look alike that mark was haveing casted? I know he had some casted and they were alot of money and flowed close to what my indy head did.
As far as I know, we sent Mark a head and he used it. Filled with hard-block and then opened it up. I know at the time, there was another version of head job he offered which was almost double the money. That may be the one your referring to. I didnt know that Mark had his own made this way.
Yea mark has a head that he had casted it was big money. But me and him discused it and the flow numbers were pretty big and with the super farm turbo being small we didnt think it was gonna help alot cause the turbo cant really flow enuf air for the head/
ILGLEANER ![]() Orange Level Access ![]() Joined: 13 Sep 2009 Location: Willow Hill,ILL Points: 6448 |
That guy that cryed and held out would'nt be Esdon Lehn would it?? He still got his ass beat when he came back out with the new block. Still cant catch the orange .....LOL IG |
lol Im not nameing names but I will say you hit the nail on the head. And its funnay that his father in law More or less owns NTPA. or should I say owns WPI which owns NTPA
