AC 2800 diesel engine head torque sequencing
CCF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CCF Quote  Post ReplyReply Direct Link To This Post Topic: AC 2800 diesel engine head torque sequencing
    Posted: 12 Jul 2024 at 10:15pm
Does any have head torque sequencing for ac 2800 diesel got new head gasket to install
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2024 at 10:21pm
I start at 50 ft lbs, then 100 ft lbs, then 150 ft lbs and finally 165 ft lbs TWICE. Tappets at .017" cold.  There should be a paper with the new head gasket showing the torque sequence starting in the middle and working back and forth to the ends of the head.
CCF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CCF Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2024 at 7:48am
Is the gas and diesel the same sequence? The paper shows 4 cylinder and six cylinder gas only   2 of those in box nothing diesel and to boot gaskets from agco🤦‍♂️
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2024 at 7:56am
It's been DECADES since I've done a gasser, so I don't remember. Look at the map they give you and basically start in the center and go back and forth working your way towards the front and rear of the cyl head.
CCF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CCF Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2024 at 8:42am
Would all 301 motors be the same? I have an 8000 AC tech manual and the 8010? Had the 301 motor I think book at the farm and I’m not there yet.
Mine is a diesel they only gave me a torque sheet for gas so I was asking if the gas sheet I have will work for diesel motor I’m working on sorry for the confusion
Edited by CCF - 13 Jul 2024 at 8:48am
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2024 at 9:23am
The doctors prescription will work for any of the 301 and 426 engines.
automaticdave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote automaticdave Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2024 at 9:27am
My I&T book 150 # for gas & diesel, Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jul 2024 at 3:48pm
I believe that 150# was the recommended torque on those engines, but somewhere along the line, it was increased to 165#. I would imagine that as the 301 and 426 were increased in horsepower, so was the head torque.
CCF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CCF Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2024 at 4:29pm
DrAllis. On more question (I really appreciate your help I’m new the doing major engine work).   I had a friend bring a 301 from his 190? Motor not in tractor. And it has broken rocker between 3 and 4 my question is if the take rocker assembly off to replace rocker can I just follow your steps for this row of bolts since the big one are head bolts as well. Work from center out each way or is it better to unscrew tappet adjusters to take pressure off to remove rod holding rockers?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2024 at 6:45pm
Just start in the center and work back and forth on those six bolts. Do NOT remove ANY other head bolts. Blow a lot of air down inside each hole to be sure there's no oil.
CCF View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CCF Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2024 at 6:47pm
Thank you sir
This page was generated in 0.087 seconds.
