AC 220 injection pump
rc3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rc3 Quote  Post ReplyReply Direct Link To This Post Topic: AC 220 injection pump
    Posted: 02 May 2010 at 7:26pm
need to up date the injection pump on my 220 . what options does anyone have.
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2010 at 9:21am
 What options? what do you mean, is this a farm tractor are you pulling it? The rosa Master is the only pump you can bolt on to it, if you want to have a Robert Bosch you have to have what they call a Harrison drive, because the oil galley is in the way to put an inline pump on. If you want more power than a stock pump just ask your diesel guy to set it at the HP you want, I have a 210 that runs 225hp on the stock pump, we use it around the farm, its a blast to drive has been that way since 1995, and no issues .
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2010 at 2:51pm
I rebuild those pumps, as well as others. Is the flex ring breaking apart causing it to lose power and die? That is the most common problem with Roosa DB/DC pumps. We can replace the weight retainer with the new style EID so you never have flex ring problems. It is an expensive part, that I dont always put into a parade tractor, but a working tractor it is recommend. send me a pm if you need more info. I'll get back sometime friday. HTH, Ed.
This page was generated in 0.115 seconds.
