Ac 2000 plow |
AC7060IL
Joined: 19 Aug 2012 Location: central IL Points: 3631 |
Topic: Ac 2000 plowPosted: 12 Dec 2019 at 7:29pm |
Just wondering if you get your 7 bottom plow? |
Tbone95
Joined: 31 Aug 2012 Location: Michigan Points: 12370 |
Posted: 11 Dec 2019 at 1:34pm |
Well, that's good farmboy. I had a 2000 plow years back, and it was the nicest pulling nicest dirt turning plow I've ever pulled. So, if it could be done, that'd be the plow to do it.
I can barely pull 6 with my 7045 on 75% of my ground, and there's fields where I wouldn't dream of trying... Like I said, good luck, I didn't mean it negatively. BTW, 7 bottoms of what, 18's also or 16's? Makes more difference than most people think.
Edited by Tbone95 - 11 Dec 2019 at 1:36pm |
Jcfarmboy
Posted: 11 Dec 2019 at 12:48pm |
Hey tbone,
95% of my field I could pull 10 furrows but the 7 I am looking at can drop the last furrow to make it a 6. |
jiminnd
Joined: 16 Sep 2009 Location: Rutland ND Points: 2323 |
Posted: 11 Dec 2019 at 9:14am |
Would not recommend 7 for a 7030 as they are getting old but I pulled 7 with mine for 10 years when I got it new, soil type makes a huge difference. this was a 16 inch IH plow.
Edited by jiminnd - 11 Dec 2019 at 4:28pm |
Tbone95
Posted: 11 Dec 2019 at 9:05am |
You're planning to pull 7 bottoms with a 7030? Well.....good luck.
Dan Hauter
Joined: 06 Feb 2011 Location: Carlinville, IL Points: 1270 |
Posted: 10 Dec 2019 at 4:46pm |
Welcome to the Forum! There are a lot of guys on the Forum with a lot of knowledge. Enjoy!
AC7060IL
Posted: 10 Dec 2019 at 4:10pm |
Yes, I agree. You may have a better time of it to just find a plow setup to your liking. Plow setup options can be numerous. Is your 4-18 an early(28”~71cm) or later(32” ~81.3cm)? If you’re not sure, you can measure the inches(cm) from leading(bottom) edge of plow share to bottom edge of monobeam square tube. If you decide to find a replacement plow, ask or look for the later 32” type. It does excellent in heavier crop residues like corn stalks. |
Jcfarmboy
Posted: 09 Dec 2019 at 7:27pm |
It's a 4-18.
It might have been drilled to except 387 drop hole shares. It very well could be the 5 hole 392. As it has small bracket to take fifth bolt hole. It has the spring cam reset but have a line on a 7 furrow hydro reset that I might trade up to |
AC7060IL
Posted: 09 Dec 2019 at 3:25pm |
You may already know, but the AC 2000 plows had a few options. What is your plows measurements? - 4-14”? - 4-16”? - 4-18”? Is your 2000 an early 28” or later 32” clearance height? Which bottom numbers does it have 387, 392? |
john(MI)
Posted: 08 Dec 2019 at 9:43pm |
I had that problem once. I discovered if I didn't lower it it pulled fine!
Gerald J.
Posted: 08 Dec 2019 at 8:59pm |
There is a plow theme on the knowledge forum with some information on the 2000 plow. The hitch is versatile enough I took off the front bottom and was able to line up the second bottom with the tractor tire in the plow trench. 4-18 proved to be too much plow for my gas 4020. It had enough power to pull but in sticky ground the front wheels rose up way off the ground.
Gerald J. |
Jcfarmboy
Posted: 08 Dec 2019 at 7:51pm |
Thanks Mikez,
Just the 2000 plow and the 7030(7060 Injector pump installed and timing corrected) tractor. Rest of my fleet are Farmalls from grandfather and great uncle. Trying to keep as much from the family farms as possible. |
Mikez
Posted: 08 Dec 2019 at 7:46pm |
Welcome to the forum. What other orange do you have
Edited by Mikez - 08 Dec 2019 at 7:46pm |
Jcfarmboy
Posted: 08 Dec 2019 at 7:43pm |
Ok thanks guys! I will hunt down some parts!
only AC orange
Joined: 06 Dec 2014 Location: Eastern Indiana Points: 593 |
Posted: 08 Dec 2019 at 5:03pm |
Yes, Allis made the "2000" plows so bottoms could be added - I had a 3 bottom with a 1 bottom extension many years ago. So that the plow turns dirt even, you will need to find a bottom (moldboard) that matches what you presently have.
Alvin M
Posted: 08 Dec 2019 at 9:56am |
You Can Add On The Rear You Will A Need Tube Extension And Extra Bottom
Jcfarmboy
Posted: 08 Dec 2019 at 9:33am |
Hey everyone!
First post and am trying to figure out the site still. Anyways, I'm running an 2000 plow 4 furrow and wondering since it has bolt together frame (front and rear) if I'm able to put another few furrows on it. I was able to find my father's allis 7030 tractor and get her back to working condition for most part, so horsepower isn't an issue. Looking for the wisdom on here! Thanks Jeff |
