AC 200 Injection Pump |
old mack ![]() Bronze Level ![]() Joined: 06 Mar 2012 Location: Idaho Points: 13 |
![]() ![]() ![]() ![]() ![]() Posted: 06 Mar 2012 at 2:13am |
I installed a rebuilt injection pump on my uncles 200. It is the early serial number so we timed it to 24 degrees btdc. After we primed the system we started the tractor. We finally got it to fire, but it would not rev to high idle. After running for a minute or so it began to rev up a little then something gave way and the tractor quit. We decided to check the timing again and when we pulled the cover off the pump and began turning the motor to 24 degrees, we noticed the pump was not turning with the motor. So we removed the gear cover from the timing cover. The gear and the injection pump shaft are turning in the front. We are assuming that the shaft either broke, it slipped out of the slot in the other end of the pump, or something broke internally on the pump. Either way we can't find any timing marks on the pump drive gear or the idler gear it is driven by. How can we set this up so we can pull the pump off and see whats going on?
stray ![]() Orange Level ![]() ![]() Joined: 16 Aug 2011 Location: Tipton, Missour Points: 323 |
You should be able to pull the valve cover and rotate the engine tell #1 is coming up on compression, both rockers loose. Then set you timing marks on 24 degrees and then you can pull the pump.
1969 190XT series 3
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21866 |
Sounds like the pump head has siezed. If you remove the #1 line from the pump head and gently move it just out of the way, look inside the hole and turn the engine over. At some point (if the rotor shaft is really turning) you'll see a discharge hole pass by the line hole. If you never see any hole pass by, the head is siezed and junk. I doubt that your pump rebuilder will eat it. Did you do the injectors at the same time??
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5096 |
sure sounds like a seizure to me as well. Did you make sure there were 2 washers on each banjo bolt? Like DR says, did the shop work on the injectors? I have heads here. pm me if need help with this. Ed.
Thanks for the response. He did not get the injectors rebuilt. All of the copper washers were in. Thats not the news I wanted but I was thinking that might be the case. I'll let you know what we find. Thanks again
why was pump rebuilt to begin with? Was yours rebuilt, or an exchange provided? Were you trying to time it with it running? Good luck, Ed.
You said copper washers were in place. If they are copper that is the problem. They should be steel. Copper will mash too far causing the end of bolts to push the head into the rotor. MACK
ALLISMAN32 ![]() Bronze Level ![]() ![]() Joined: 13 Mar 2011 Location: Hillsboro, IN Points: 199 |
Had a couple 7000's that the dowel pins that hold the front engine adaptor plate to the engine block had worked out and would cause the head of the pump to seize.Hard problem to find if not knowing what to look for. On the 7000's the dowel pins worked out of the block, i think there was one on each side that could do this. When we finally figured it out i drove a pin in, tapped the block with pipe threads and inserted a pipe plug. Not sure without looking if the 200 is made the same as a 7000. Actually maybe it was a standard coarse thread and a set screw in the hole to keep the pin from backing out.
200's aren't normally known for timing cover dowel pins falling out, but 7000's sure are. The cause is the side frames extending too far ahead of the engine and not being channel iron, allowing too much flex in some cases and working the dowels loose.
injpump Ed- the pump is seized, is the head repariable or will we have to put a new pump head on it?
pump needs to be torn down and rebuilt, again. I have driveshafts, as well as a good used head. Head will be pressed apart to determine cause of seizure. very rare to be able to reuse a seized head, though it has been done. Ed.
Thanks
Ed, How much for a drive shaft and a used head?
pmme and we can discuss.
